2D vertical axis wind turbine, OpenFOAM beginner
Like Tree12Likes
Old   June 5, 2013, 03:14
Post 2D vertical axis wind turbine, OpenFOAM beginner
Anand Lobo
Boloar is on a distinguished road
Hey all.
I've recently begun using CAELinux, and I've discovered OpenFOAM as a result.
I want to do a small, relatively simple study of a vertical-axis wind turbine. At least (like a lot of things), it seems simple in concept. I have not studied CFD before, but some of the concepts seem fairly intuitive.
There's this video on Youtube which was apparently done using OpenFOAM, but there are no hints on how to recreate their work. I've created a 2D FreeCAD model with three blades and a shaft like they have, but I have no idea (yet) how to define the wind flow, boundaries, rotation, etc.
As this is a side project I might take a lot of time learning how to operate OpenFOAM from scratch - and I'm not exactly a programming or command-line wizard, although I can more or less manage. So if someone can give me guidelines that'd be really great.
I'd just like to set up wind flow from one direction, and plop the model in the middle and see what happens, and then try again with the model rotating. I'm sure it's not as simple as that (I'm reading through the documentation in my free time), but any help is appreciated to speed things up!
Thanks!
Boloar is offline   Reply With Quote
Old   June 5, 2013, 03:36
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Here is the case used to produce the movie on Youtube.
https://dl.dropboxusercontent.com/u/...-TSR1.0.tar.gz
Best
sylvester, Alhasan, JR22 and 3 others like this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   June 5, 2013, 03:59
Anand Lobo
That is ... awesome.
Please excuse my surprise, I was expecting a few pointers on the programming, or directions to the documentation, not the original files, hahah.
Thank you very much linneman! This should speed up my learning curve appreciably ^_^
Old   June 6, 2013, 07:46
Thumbs up Can you explain GGI in a relatively simple manner?
Anand Lobo
I've searched online and all I find area a few forum threads from people who already understand its intricacies.
I understand that it allows for a rotating domain, but how does it do so?
Old   June 6, 2013, 09:23
linnemann's Avatar
Niels Nielsen
http://www.openfoam.org/version2.1.0/ami.php
Balzuka and RichJoe like this.
Linnemann
Old   June 6, 2013, 23:52
Anand Lobo
Thank you very much, linneman. I had not seen "arbitrary mesh interface", I thought it was just "General Grid Interface" so that was what I searched for.
Much appreciated!
Old   June 11, 2013, 00:43
Default change the shape of the non-AMI region
Anand Lobo
Hi linneman,
Thanks for the help so far. After studying the tutorial incompressible/pimpleDyMFoam/mixerVesselAMI2D, I have been able to create a preliminary blockMesh to use with my STL file. I'll start to work on the snappyHexMesh when I have time.
My blockMeshDict file
Right now, the non-AMI region is simply a larger circle around the AMI. Can I perform the airflow analysis like that, or would I need to make it square as in your case to have an inlet/outlet?
If so, could you give me a hint how to make it a square region while maintaining the AMI interface?
Old   June 18, 2013, 02:25
Default I think I'm making progress. Help will be appreciated!
Anand Lobo
For a while I had an error trying to run snappyHexMesh, listed here: http://www.cfd-online.com/Forums/ope...or-2d-ami.html
After I made a small hole in the center of the blockMesh, snappy was able to work.
BUT, my blockMesh is being reformed from a square to a circle. Why is this?
Also, the STL files appear to become incorporated as part of the mesh, rather than becoming boundaries. See the attached image. Could someone advise me how to get the VAWT blades to become holes/boundaries in the mesh, rather than part of the mesh?
This is my blockMesh: http://www.cfd-online.com/Forums/att...artialmesh.jpg
After using snappyHexMesh, the result is in the attached image.
Here are my blockMeshDict and snappyHexMeshDict files for your perusal. You should be able to substitute them directly in the tutorials/incompressible/pimpleDyMFoam/ tutorial.
Old   June 21, 2013, 07:38
Default pimpleDyMFoam crashing!
Anand Lobo
After a fair amount of work, and repurposing the tutorial incompressible/pimpleDyMFoam/propeller, I was successfully able to make a 2D mesh with my VAWT model.
However, when I try to run pimpleDyMFoam, it crashes almost immediately. The mesh generation took me almost 2 weeks to figure out ... I have no idea how to troubleshoot a program crash. Let me know if you need my case files to help!
This is the error:
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone AMIsurface_z
Reading field p
Reading field U
AMI: Creating addressing and weights between 24612 source faces and 24612 target faces
AMI: Patch source weights min/max/average = 2.19635e-06, 1.00181, 0.856611
AMI: Patch target weights min/max/average = 0, 1.80718, 0.854741
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
bounding k, min: 0 max: 0.375 average: 0.375
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
 at sigaction.c:?
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  void Foam::divide<Foam::fvPatchField>(Foam::FieldField<Foam::fvPatchField, double>&, Foam::FieldField<Foam::fvPatchField, double> const&, Foam::FieldField<Foam::fvPatchField, double> const&) at ??:?
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#6  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::average<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#7  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::average<double>(Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) at ??:?
#8  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::average<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#9  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::average<double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#10  Foam::bound(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensioned<double> const&) at ??:?
#11  Foam::incompressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) at ??:?
#12  Foam::incompressible::RASModel::adddictionaryConstructorToTable<Foam::incompressible::RASModels::kOmegaSST>::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) at ??:?
#13  Foam::incompressible::RASModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) at ??:?
#14  Foam::incompressible::turbulenceModel::addturbulenceModelConstructorToTable<Foam::incompressible::RASModel>::NewturbulenceModel(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) at ??:?
#15  Foam::incompressible::turbulenceModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) at ??:?
#16
 at ??:?
#17  __libc_start_main at ??:?
#18
 at ??:?
Floating point exception (core dumped)
Old   June 24, 2013, 04:03
Laurent Fitschy
GDTech is on a distinguished road
That error means you are dividing by zero when initializing your turbulence model. Check your k and omega files and replace zero values by small non zero ones ie. 1e-12.
Hope this help,
Regards.
Alisa_W likes this.
GDTech is offline   Reply With Quote
Old   June 25, 2013, 04:46
Anand Lobo
Originally Posted by GDTech View Post
Thanks, for the suggestion; I went and did that, but I'm still getting the same error it seems. No zero values in the initial conditions except in p.
So far I've used the mixerVesselAMI2D and propeller tutorials to try and figure out the AMI stuff. I've got the mesh correct now, but I might be confusing myself with those turbulence models. Gonna look over the wingMotion tutorials again and make sure I'm following that model correctly. Wish me luck.
Thanks!
Old   July 4, 2013, 03:30
Default Working 2D VAWT wind tunnel!
  #12
Anand Lobo
Thanks to the gracious help of Linneman and Kilroy, among others, (and after a month of sweating over it) my VAWT simulation is up and running.
A guide to anyone else who wants to attempt this: I took the rotating AMI implementation from $OPENFOAM_TUTORIALS/incompressible/pimpleDyMFoam/propeller, and attempted to turn it into a 2D mesh using my own STL files. Once the mesh was successfully produced I substituted in the boundary conditions and initial conditions from wingMotion2D/pimpleDyMFoam. After some tweaking it was successful, or at least it hasn't crashed yet ...
Old   August 26, 2013, 22:15
Default how to find the mixerGgiFvMesh file
  #13
loic tachon
lolo is on a distinguished road
Hi every body
Im trying to simulate a verticale axe wind turbine and the following error message appear :
Unknown dynamicFvMesh type mixerGgiFvMesh
Have I to install a library ?
Where can I find the good library ?
Thanks a lot
lolo is offline   Reply With Quote
Old   August 26, 2013, 23:58
Anand Lobo
I have not used mixerGgiFvMesh so I cannot advise you there. I am using the latest OpenFOAM 2.2.x from GitHub in Linux. I believe GGI (general grid interface) has been replaced by AMI (arbitrary mesh interface), if I am not mistaken.
What I did is use the tutorial incompressible/pimpleDyMFoam/propeller as a basis for my simulation - it is 3D, but I turned it into a 2D simulation after some work, and used my own STL model files rather than the included .obj models. Then I used the boundary and initial conditions from pimpleDyMFoam/incompressible/wingmotion* to get the fluid conditions for airflow rather than the water flow of the other tutorial.
You will have very little luck with a VAWT simulation if you don't go through those tutorials first. You can take a look at linnemann's files attached in post #2 of this thread, but keep in mind that was made with OpenFOAM 1.6-ext and so is slightly out of date compared to the latest OpenFOAM. It was still helpful as a guide, though. Best of luck!
Old   August 27, 2013, 17:48
loic tachon
Thank you for your response.
Now an other problem appears.
I tried to install the old version of OpenFoam 1.6-ext, but now I wanted to get back the 2.2.0 version. I have a mac.
Now I have the following error message :
-bash: wcleanAll: command not found
When I try to compilate all the following error message appears:
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
I already do this in the ".profile" file :
source OpenFOAM/OpenFOAM-2.2.0/etc/bashrc
When I do :
echo $WM_PROJECT_DIR
Nothing appears !!
I really need help !!
Thanks a lot for your help guys !!
Old   August 28, 2013, 10:32
loic tachon
I solved my problem,
Now i have to force to source the environment variable in the terminal thanks to this command line :
. ~/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc
When I do :
Nothing appears !!
Old   August 28, 2013, 10:35
Default propeller tutorial
  #17
loic tachon
Hi Boloar,
I would like to run the propeller tutorial.
Do you the procedure that I have to do ?
I did
./Allrun
and after
pimpleDyMFoam
But the following error message appears :
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for walls
Thanks for your help !
Old   May 8, 2014, 05:54
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
Hi Foamers
I wanna simulate vertical axis wind turbine in order to it rotates freely because of aerodynamics forces. My target is to calculate the velocity that rotor turns (start up). can every one tell me the steps of doing it using OpenFOAM.
thanks all
Rasoul
desert_1250 is offline   Reply With Quote
Old   May 8, 2014, 06:59
Anand Lobo
Originally Posted by desert_1250 View Post
Hi Foamers
I don't know if you can figure that with OpenFOAM. You, the user, have to supply the rotation parameters for the simulation mesh - it will not start rotating on its own. If you provide wind-speed parameters and a stationary mesh, it will give you results for a stationary VAWT. To figure out the start-up speed, you'd need to physically build it and test it ... or perhaps go talk to a physicist/aeronautical engineer who can help.
What I did is use the OpenFOAM tutorial
as a basis for my simulation - it is a 3D tutorial, but I turned it into a 2D simulation (by making it only one cell thick), and used my own .stl model files rather than the included .obj propeller model files. Then (after some effort) I substituted in the boundary and initial conditions from
incompressible/pimpleDyMFoam/wingmotion*
to get the fluid parameters for airflow rather than the water flow of the original propeller tutorial.
Old   May 8, 2014, 12:45
s.rasoul_varedi
dear Boloar
thanks for your quick reply!
I simulated 3kW SB-VAWT using OF and extracted the specification of my turbine, successfully (such as Cp vs Lambda and designed point, power Curve, Torque vs Rotational Speed and etc). this is done about two years ago. After that, (As you told too) I built it and tested in front of wind tunnel. Now, Turbine has a start-up problem and the dead-band region accrues. because of this, i think that the calculation of start up wind speed is very important and necessary. I must know it to reduce the resistance torque such as roller-bearing, Kagging tourqe of the generator, parasitic drag of struts and other resistance forces that there is a possibility.
I think that there is possible to do this using Open-Source OpenFOAM software. I am very happy if any one Shared his experiences in this field.
thanks a lot.
Rasoul
vawt wind turbine, wind tunnel
[ICEM] Boundary conditions in copy-rotate 3-bladed vertical axis wind turbine pollenhavy ANSYS Meshing & Geometry 2 February 17, 2017 17:01
Wind turbine analyses in OF - first steps / beginner / cadcae OpenFOAM Running, Solving & CFD 3 March 1, 2015 16:00
Vertical axis wind turbine simulation vincentwks ANSYS 0 April 10, 2012 04:27
Vertical Axis Wind Turbine courtjester140 ANSYS 2 June 22, 2010 10:27
vertical axis wind turbines pyong Main CFD Forum 1 March 14, 2005 09:35
