.setSet problems
Old   July 8, 2013, 19:31
Default .setSet problems
Gabriel de PInho RImoli
Grimoli is on a distinguished road
Hello
How is everyone doing??
So,Im doing a OpenFoam when my geometry is based on parallel boxes,with a retangular base,as shown :
cellSet heater new boxToCell (0.049925 0.050 0 ) (0.155925 0.156 0.004)
cellSet heater add boxToCell (0.049925 0.050 0.004)(0.155925 0.052 0.018) //1
cellSet heater add boxToCell (0.049925 0.058 0.004)(0.155925 0.060 0.018) //2
cellSet heater add boxToCell (0.049925 0.066 0.004)(0.155925 0.068 0.018) //3
cellSet heater add boxToCell (0.049925 0.074 0.004)(0.155925 0.076 0.018) //4
cellSet heater add boxToCell (0.049925 0.082 0.004)(0.155925 0.084 0.018) //5
cellSet heater add boxToCell (0.049925 0.090 0.004)(0.155925 0.092 0.018) //6
cellSet heater add boxToCell (0.049925 0.098 0.004)(0.155925 0.100 0.018) //7
cellSet heater add boxToCell (0.049925 0.106 0.004)(0.155925 0.108 0.018) //8
cellSet heater add boxToCell (0.049925 0.114 0.004)(0.155925 0.116 0.018) //9
cellSet heater add boxToCell (0.049925 0.122 0.004)(0.155925 0.124 0.018) //10
cellSet heater add boxToCell (0.049925 0.130 0.004)(0.155925 0.132 0.018) //11
cellSet heater add boxToCell (0.049925 0.138 0.004)(0.155925 0.140 0.018) //12
cellSet heater add boxToCell (0.049925 0.146 0.004)(0.155925 0.148 0.018) //13
cellSet heater add boxToCell (0.049925 0.154 0.004)(0.155925 0.156 0.018) //14
cellZoneSet heater new setToCellZone heater
THe problem is that I need to separate it in 2 regions,the parallel boxes ( 1 to 14) need to be separated from the base,but Im having problem because the command boxToCell seems to be used only when the boxes are connected to the main on(the one without any number)
How I am supposed to make a region between these boxes??Please help me
Grimoli is offline   Reply With Quote
Old   July 8, 2013, 19:34
I tried to do this,but it's giving a error on aleta11 ,but I dont know why!!:
Whats wrong??
cellSet aletas new boxToCell (0.049925 0.050 0.004)(0.155925 0.052 0.018) //1
cellSet aletas add boxToCell (0.049925 0.058 0.004)(0.155925 0.060 0.018) //2
cellSet aletas add boxToCell (0.049925 0.066 0.004)(0.155925 0.068 0.018) //3
cellSet aletas add boxToCell (0.049925 0.074 0.004)(0.155925 0.076 0.018) //4
cellSet aletas add boxToCell (0.049925 0.082 0.004)(0.155925 0.084 0.018) //5
cellSet aletas add boxToCell (0.049925 0.090 0.004)(0.155925 0.092 0.018) //6
cellSet aletas add boxToCell (0.049925 0.098 0.004)(0.155925 0.100 0.018) //7
cellSet aletas add boxToCell (0.049925 0.106 0.004)(0.155925 0.108 0.018) //8
cellSet aletas add boxToCell (0.049925 0.114 0.004)(0.155925 0.116 0.018) //9
cellSet aletas add boxToCell (0.049925 0.122 0.004)(0.155925 0.124 0.018) //10
cellSet aletas add boxToCell (0.049925 0.130 0.004)(0.155925 0.132 0.018) //11
cellSet aletas add boxToCell (0.049925 0.138 0.004)(0.155925 0.140 0.018) //12
cellSet aletas add boxToCell (0.049925 0.146 0.004)(0.155925 0.148 0.018) //13
cellSet aletas add boxToCell (0.049925 0.154 0.004)(0.155925 0.156 0.018) //14
cellZoneSet aletas new setToCellZone aletas
cellSet topAir clear
cellSet topAir add cellToCell heater
cellSet topAir add cellToCell aletas
cellSet topAir invert
cellZoneSet topAir new setToCellZone topAir
Old   July 9, 2013, 03:39
someone help please =/
Old   July 9, 2013, 04:52
Nima Samkhaniani
nimasam is on a distinguished road
Dear,
look carefully at chtmultiRegion tutorial, you will find how to recall the space between box, in brief
you need a create a CellSet, then add to this CellSet all present boxes, then invert cellSet to choose remain cells
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   July 23, 2013, 16:55
what does the function invert does??
Old   July 24, 2013, 04:17
Nima Samkhaniani
consider you have two sets A and B, which B is a sub-set of A, when you use invert B,
means all cells which are in A but not in B
Old   July 25, 2013, 16:59
OKay,i have a problem now that i cant solve!!I have 2 regions in the same place.How do I erase a part of it??Is there a way I can do it ??I have 2 regions on the same place,i want to clear to it so the program doesnt crash.
Old   July 25, 2013, 18:30
Nima Samkhaniani
look at tutorials its easier way to find each dictionary how works , however you can use command remove, to remove one cellSet, or easily you can go to polyMesh in setSet folder and see whats your cellSet name is and remove it manually
Old   July 31, 2013, 13:13
i managed my problem thanks you
Where I can find the chtmultiregion tutorial??I tried to find it on google and on open foam website but i didnt found it.Any links??I want to improve my skills at OPenFOAM
Old   July 31, 2013, 13:24
Nima Samkhaniani
look at OpenFOAM tutorials the address is :
/tutorials/heatTransfer/chtMultiRegionFoam
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
