what is correct boundary condition for K-w sst model at y+<1?
Like Tree5Likes
  • 1 Post By andre.weiner
  • 4 Post By andre.weiner
Old   August 4, 2013, 14:35
Default what is correct boundary condition for K-w sst model at y+<1?
mechy is on a distinguished road
Hi
I found some thread about k-w sst boundary conditions
unfortunately they are not clear in low y+
please let me know what is correct boundary conditions for k, w and nut
for y+<5
Best Regards
mechy is offline   Reply With Quote
Old   August 4, 2013, 15:42
Andre Weiner
andre.weiner is on a distinguished road
Hello!
omega:
Menter's automatic wall funcion works for all parts of the momentum boundary layer,
in openfoam it's the omegaWallFunction http://www.cfd-online.com/Wiki/Near-...k-omega_models
or you use the solution for the viscos sublayer to set the boundary value
http://turbmodels.larc.nasa.gov/sst.html (there is an equation for omega_wall)
for y^+<5 both give the same results
k:
fixed value 0 or
zero gradient
if you look at same results for k near the wall (from other simulations for example), you will see that both are valid (again for y^+<5)
nut:
calculated or
fixed value 0 or
nutLowReWallFunction (sets the value to zero and provides a function for calculating y^+ which is needed for the yPlusRAS tool)
This is what i tried so far and it worked for mi :-)
Best regards, Andre
chliu likes this.
andre.weiner is offline   Reply With Quote
Old   August 5, 2013, 03:51
Originally Posted by andre.weiner View Post
Hello!
nut:
calculated or
fixed value 0 or
Best regards, Andre
thanks so much for your answer
what function should be set for calculating y+ ? and how set it ?
can you attached an example for k,w,nut (initial file at folder 0)?
Best Regards
Old   August 5, 2013, 10:29
Joachim
Joachim is on a distinguished road
Actually, I think that nutLowReWallFunction is a wall function for low-Re turbulence models. If you use LaunderSharmaKE and have y+ ~ 60, you can use it for example.
Also, try using 1e-9 (or any small value) rather than 0 when imposing the BC.
Good luck!
Joachim is offline   Reply With Quote
Old   August 5, 2013, 14:17
Andre Weiner
for k:
    myWall
        type            zeroGradient;
// or
    myWall
        type            fixedValue;
        value           uniform 0;
for omega:
    myWall
        type            omegaWallFunction;
for nut:
    myWall
        type            fixedValue;
        value           uniform 0;
// or
    myWall
        type            calculated;
        value           uniform 0;    // optional value entry
// what i prefer
    myPatch
        type            nutLowReWallFunction;
I don't know for what the nutLowReWallFunction schould or schloud not be, but if you take little look at the code:
it sets nut to zero:
tmp<scalarField> nutLowReWallFunctionFvPatchScalarField::calcNut() const
    return tmp<scalarField>(new scalarField(patch().size(), 0.0));
and provides a function for y+:
tmp<scalarField> nutLowReWallFunctionFvPatchScalarField::yPlus() const
    return y*sqrt(nuw*mag(Uw.snGrad()))/nuw;
Regards, Andre
Tauseef, randolph, calf.Z and 1 others like this.
Epsilon boundary condition for walls in LamBremhorst LowRe model maruthamuthu_venkatraman OpenFOAM 1 April 21, 2019 06:25
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
SST model and boundary layers Rodrigo Basniak CFX 7 March 27, 2008 14:19
