surface sampling with a step smaller than outputTime
Old   August 9, 2013, 12:22
Default surface sampling with a step smaller than outputTime
Seiji Adachi
seiji_adachi is on a distinguished road
Hi foamers,
Sampling data on a surface with a time step smaller than outputTime
seems not working. In pisoFoam/les/pitzDaily/system/controlDict,
endTime 0.001;
deltaT 1e-05;
writeControl timeStep;
writeIntermal 100;
surfaceSampling
outputControl timeStep;
outputInterval 10;
are set in hoping that sampling will be done in 1e-05 x 10 = 0.0001 interval.
It is, however, done in 1e-05 x 100 = 0.001 interval, which is the same as
outputTime. Time directories are created correctly but almost all of them
are empty! Here are files and directories after calculation:
ibp-ak-svr02:..les/pitzDaily $ ls
0 0.001 constant log postProcessing system
ibp-ak-svr02:..les/pitzDaily $ ls postProcessing/surfaceSampling/
0.0001 0.0002 0.0003 0.0004 0.0005 0.0006 0.0007 0.0008 0.0009 0.001
ibp-ak-svr02:..les/pitzDaily $ find postProcessing/ -name "*.vtk"
postProcessing/surfaceSampling/0.001/U_nearWall.vtk
I am using OpenFOAM-2.2.0 now. In version 2.1.1, sampling can be correctly
done:
pcsea:..les/pitzDaily $ ls surfaceSampling/
pcsea:..les/pitzDaily $ find surfaceSampling/ -name "*.vtk"
surfaceSampling/0.0001/U_nearWall.vtk
surfaceSampling/0.0003/U_nearWall.vtk
surfaceSampling/0.0009/U_nearWall.vtk
surfaceSampling/0.0007/U_nearWall.vtk
surfaceSampling/0.0004/U_nearWall.vtk
surfaceSampling/0.0005/U_nearWall.vtk
surfaceSampling/0.0008/U_nearWall.vtk
surfaceSampling/0.0006/U_nearWall.vtk
surfaceSampling/0.0002/U_nearWall.vtk
Is this a bug in version 2.2.0? or something is missing in my operation.
Full controlDict is attached at the bottom.
regards,
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application pisoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
//endTime 0.1;
endTime 0.001;
deltaT 1e-05;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
probes
type probes;
functionObjectLibs ("libsampling.so");
enabled true;
outputInterval 1;
fields
p
probeLocations
( 0.0254 0.0253 0 )
( 0.0508 0.0253 0 )
( 0.0762 0.0253 0 )
( 0.1016 0.0253 0 )
( 0.127 0.0253 0 )
( 0.1524 0.0253 0 )
( 0.1778 0.0253 0 )
fieldAverage1
type fieldAverage;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputControl outputTime;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
surfaceSampling
// Sample near-wall velocity
type surfaces;
// Where to load it from (if not already in solver)
enabled true;
// outputControl outputTime;
outputInterval 10;
interpolationScheme cellPoint;
surfaceFormat vtk;
// Fields to be sampled
fields
U
surfaces
nearWall
type patchInternalField;
patches ( lowerWall );
distance 1E-6;
interpolate true;
triangulate false;
seiji_adachi is offline   Reply With Quote
Old   August 14, 2013, 06:01
Seiji Adachi
Hello all,
After updating to OpenFOAM-2.2.1, surface sampling with a smaller
interval became possible. I will never use version 2.2.0. Thank you
for your consideration.
Best,
Old   January 3, 2014, 07:39
kkpal is on a distinguished road
My version is 2.2.2, but this problem still remain.
Now I have to write down all the fields with very short interval, which is very memory consuming!
Originally Posted by seiji_adachi View Post
Hello all,
Best,
kkpal is offline   Reply With Quote
Old   April 15, 2014, 04:44
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
Hi all,
I am new in OF, i am unable to understand, how to give probe for a surface or say, for a patch..??
thanks and regards,
Adarsh Tiwari
adarsh tiwari is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
