number of iterations exceeded From function specieThermo |
September 16, 2010, 23:36 |
Alex
Rep Power: 16 |
I am trying to solve a case with sonicFoam with time dependent BC (INLET ={p =45Mpa-->101325 Pa, U=1000-->0 and T 2000k-->300K} and outlet = zerogradient for all fields). After some iterations i got this error message: Maximum number of iterations exceeded#0 Foam::error:rintStack(Foam::Ostream&) in "/home/moumen/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/moumen/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/moumen/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" #3 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/moumen/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" #4 main in "/home/moumen/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/sonicFoam" #5 __libc_start_main in "/lib/libc.so.6" #6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68. FOAM aborting Aborted Has anyone experienced an error like the above? Any suggestions on what it might be? Any help will be appreciated Best regards. Last edited by bruxellois; September 16, 2010 at 23:42. Reason: error |
September 17, 2010, 03:03 |
Christian Lucas
Rep Power: 17 |
this problem is quite common. Have a look through the forum. The problem is most probably related to pressure field. Have a look at it at a time step before the error occurs. I guess you have negative pressures, so the thermophysical library crashes. Regards, Christian |
September 17, 2010, 03:09 |
Alex
Rep Power: 16 |
thanks for your response,
If so how can i fix that! |
October 27, 2010, 06:16 |
#4 | ||
Alessandro
Rep Power: 16 |
Hi have solved the problem by changing the controlDict file:
August 28, 2013, 04:48 |
starter
Rep Power: 15 |
All
I have the same issue and I have been referring the forum but cannot find a solution that can get rid of this error for me. I have tried Alessandro's method but to no avail. Alex, kindly advise what you did to resolve max number of iterations exceeded. I shall be very obliged. Regards |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Parallel rasInterFoam | openfoam_user | OpenFOAM Running, Solving & CFD | 4 | November 1, 2008 04:14 |
MRFSimpleFoam amp cyclic patches | david | OpenFOAM Running, Solving & CFD | 36 | October 21, 2008 21:55 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
