twoPhaseEulerFoam: turbulence on produces instability of drag phase
Old   January 19, 2010, 11:45
Default twoPhaseEulerFoam: turbulence on produces instability of drag phase
Florian Krause
florian_krause is on a distinguished road
I am trying to simulate a turbulent air - solid particle two-phase flow in a vertical pipe using twoPhaseEulerFoam. I added a source term (as in channelFoam) in the Ub (continous phase) equation to sustain the flow for the use of cyclic BC's. Further I use wedge BC's.
When I switch turbulence off, everything works fine, meaning I get reasonable axial velocity profiles for Ua and Ub.
From the above state I switch turbulence on, and the velocity of the drag phase Ua starts developing in a wrong "unsteady shape", see the attached picture.
setup:
- OF-1.6.x
- fvSolution and fvScheme are taken from the bed tutorial
- ppForces and kinetic theory is switched off
- drag model: SchillerNaumann
- k is calculated using k = 3/2 (I*U)^2
- epsilon is calculated using epsilon = (c_mu^0.75*k^1.5) / l
- The continous phase bulk Re number is 2.3E+4
I am wondering why the drag phase behaves in such a strange way, after switching on the turbulence model....
Do you have any suggestions, what might be the reason for this behaviour? Or did anyone oberserved similar problems?
Thanks in advance,
Florian
florian_krause is offline   Reply With Quote
Old   October 11, 2013, 09:02
Default Same problem
Pedro Lopes
pedromiglopes is on a distinguished road
Hi Florian,
I've tried to do the same study, i.e. an bubble column, and happened the same problem as you report. Did you found an solution for your problem with the k-e model?
Regards,
Pedro
pedromiglopes is offline   Reply With Quote
Multiphase Turbulence: K-E per phase meangreen FLUENT 0 August 20, 2009 18:34
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
How to activate just one phase turbulence model? Trodeme FLUENT 1 January 26, 2007 14:50
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
