[swak4Foam] groovy BC
Old   October 25, 2013, 12:31
Default groovy BC
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Hi foamers,
i'm using groovy BC to express relation between pressure in two different patches. the problem is that expression takes average value of pressure in each patch and input it in my equation to output one value assigned to patch with groovy BC. while i want this equation to be applied for every cell not the patch as a whole and value for every cell to be evaluated from corresponding cells pressure in the two other patches (the three patches have same number of cells).
is it possible with groovy BC.
Ahmed Khattab is offline   Reply With Quote
Old   October 28, 2013, 15:48
Assistant Moderator
Bernhard Gschaider
Originally Posted by Ahmed Khattab View Post
Hi foamers,
First: on a patch you have faces not cells (that may seem minor but it makes reading the questions harder because on has to guess what you mean)
Second: what is the third patch
Something like this is possible if the two patches are "mapped" patches. Have a look at the examples there are two mapping-examples in Examples/test
For non-mapped-patches this is not supported and I have explained multiple times on the forum why not
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 5, 2013, 11:09
ahmed
i tried mapFields and i got this error message
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/khattab/OpenFOAM/khattab-2.1.0/run/tutorials/heatTransfer/chtMultiRegionSimpleFoam/masterCase4/processor0/system/controlDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
i don't know what i must do?
another thing. i want to take two fields only from source case (U,P) which not only fields in source case or target case.
thanks in advance
Old   November 7, 2013, 06:08
Assistant Moderator
Bernhard Gschaider
cannot find file
FOAM exiting
thanks in advance
How is that related to the topic of this thread? Does it only happen if you use a groovyBC or is it a general problem with mapFields in parallel and multi-region cases (in that case I suggest you start a new thread)
Old   November 7, 2013, 07:51
ahmed
thanks for your reply, i already started new one.
http://www.cfd-online.com/Forums/ope...i-regions.html
but this new thread is with another problem related to multiregions.
for my problem with multiprocessor i didn't find solution but i used one processor to overcome it.
thanks in advance.
cell, groovy
[swak4Foam] Groovy BC - time dependend Inlet Tobi OpenFOAM Community Contributions 20 August 27, 2020 09:22
[swak4Foam] How to use groovy Boundary conditions Zhiheng Wang OpenFOAM Community Contributions 8 November 6, 2019 09:28
[swak4Foam] groovy boundary condition for pressure Ahmed Khattab OpenFOAM Community Contributions 4 November 14, 2015 20:18
[swak4Foam] groovy BC - which value is used ThorgrimmCFD OpenFOAM Community Contributions 2 May 7, 2015 04:06
[swak4Foam] using groovy boundry condition in multiphase problom javad814 OpenFOAM Community Contributions 1 November 30, 2011 16:29
