Any hints for user-defined BCs without using groovyBC/Swak4Foam?
Old   March 21, 2013, 08:22
Question Any hints for user-defined BCs without using groovyBC/Swak4Foam?
David Long
keepfit is on a distinguished road
Hi Foamers,
as I am not very clear about the idea/principle behind Swak4Foam/groovyBC, so I was wondering, is there some easy way to define some customized boundary conditions?
For instance: assuming inlet z coordinates is from z = 0 m to z = 4 m, I want to define an "alpha 1" source from z =0 to z =2 m at the inlet with a velocity 2 m/s at x-axis, while the pressure of outlet is fixed to 0.
Or more complex, I want the source velocity varying from: Vx = | 2*sin(t* 2*Pi/T) | (absolute value) , where T is the period.
So how to implement these BCs without using predefine Swak4Foam?
Any recommendations or hints will be highly appreciated.
keepfit is offline   Reply With Quote
Old   March 21, 2013, 09:02
Assistant Moderator
Bernhard Gschaider
Originally Posted by keepfit View Post
Hi Foamers,
There is the coded-BC (since OF 2.0) that allows you to include little C++-programs that calculate your BC. If you're fluent in C++ and know the OF-API well then you might be as fast writing your BC with it as you might be with groovyBC.
The expressions you mention would be "pos().z<2 ? 1 : 0" for alpha1 (if I understand your description correctly) and "2*sin(time()*2*pi/42)" (with a period 42) in groovyBC which I think (but I'm biased) is pretty straightforward. It's a bit more typing (but not exactly rocket-science) in coded/C++
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 21, 2013, 09:13
Default Implement your own Boundary Condition
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
There is a tutorial by Hakan Nilsson from Chalmers University on how to implement your own boundary condition. You can find it here:
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/implementBoundaryCondition.pdf
The tutorial seems to be current as of version 2.0.x.
JR22 is offline   Reply With Quote
Old   March 21, 2013, 13:54
David Long
thanks, it's great help.
What I want is to code a small fraction of C++ and make it usable for calculating the specified BCs. The difficult part is the OF-API that operates on the mesh properties like cell faces, coordinates and so on.
In this way I might be able to make a wave-generation BCs with varying the "alpha1" position according to the wave period T and other parameters.
Old   October 29, 2013, 09:10
brocco is on a distinguished road
Hi bernard!
Yesterday I started to have a look on swak and in particular the capabilities of groovybc,but in truth i've not understood a lot !(my brain after thesis is cooked!). I was interested to know how to produce the input speed with only conditions of geometric type as you suggested to keepfit for alpha1 but obviously for me is a velocity vector.
The idea is to produce sub-areas without having to change each time the mesh. For example on a square produce strips with input speed not anything. How could I do?
for example
1<x<3, 0<y<1, & 4<x<6, 2<y<3 ecc....
suggestions?
brocco is offline   Reply With Quote
Old   October 29, 2013, 11:41
Assistant Moderator
Bernhard Gschaider
Originally Posted by brocco View Post
Hi bernard!
for example
suggestions?
That'd be with the ?: operator. For the two rectangles in you example (I guess your & was meant to be a | ) it should be something like
"((1<pos().x && pos().x<3 && 0<pos().y && pos().y<1) || (4<pos().x && pos().x<6 && 2<pos().y && pos().y<3)) ? 1 : 0"
would give the value 1 on these two rectangles and 0 elsewhere
Old   October 30, 2013, 05:56
thanks a lot!works perfectly...
caldaiasemplificata_ingresso_ariaprimaria
type groovyBCFixedValue;
valueExpression "((1<pos().x && pos().x<2 && -22<pos().y && pos().y<-21) || (3<pos().x && pos().x<4 && -28<pos().y && pos().y<-26)) ? vector(0,0,0.6) : vector(0,0,0)";
thanks again
boundary condition, user defined function
[ICEM] How can I define different zones in ICEM? llrr ANSYS Meshing & Geometry 14 February 12, 2017 13:44
UDF link fortran source yorelchr Fluent UDF and Scheme Programming 0 February 7, 2013 03:44
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 11:58
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
