Solution is NOT APPROPRIATE WHEN COMPARED TO CFX
Like Tree2Likes
  • 1 Post By betakv
  • 1 Post By kmooney
Old   February 17, 2014, 23:54
Default Solution is NOT APPROPRIATE WHEN COMPARED TO CFX
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
Hi all,
I am trying to do some simulations in turbulent modelling using OpenFOAM and also comparing the results with CFX.
the velocity in the OF's results is nearly zero due to no pressure drop, while in CFX, i am satisfied with the velocity range of 65 m/s with some pressure drop.
The solvers I have used for trial are
1) rhoLTSPimpleFoam
2) rhoSimpleFoam
3) simpleFoam
[the 'P' file] [/*--------------------------------*- C++ -*----------------------------------*\
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0.956e5;
boundaryField
HOUSING
type zeroGradient;
VALVE
type zeroGradient;
INLET
type zeroGradient;
OUTLET
type fixedValue;
value $internalField;
[The T file][/*--------------------------------*- C++ -*----------------------------------*\
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 487.94;
boundaryField
HOUSING
type fixedValue;
value uniform 298;
VALVE
type fixedValue;
value uniform 298;
INLET
type fixedValue;
value uniform 487.94;
OUTLET
type zeroGradient; //inletOutlet;
// value $internalField;
// inletValue $internalField;
[the U file] [/*--------------------------------*- C++ -*----------------------------------*\
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
HOUSING
type fixedValue;
value uniform (0 0 0);
VALVE
type fixedValue;
INLET
type pressureInletVelocity; //flowRateInletVelocity;
// massFlowRate constant 0.00085;
OUTLET
type flowRateInletVelocity; //inletOutlet; //fluxCorrectedVelocity;
//inletValue uniform (0 0 0);
Except some flow pattern variations all the results are nearly same for all the solvers.
I have to solve it ASAP, else my instructor will kick my a$$
Thanks in Advance,
ragards,
Adarsh Tiwari
adarsh tiwari is offline   Reply With Quote
Old   April 2, 2014, 02:29
adarsh tiwari
nothing at all ....????
Old   April 2, 2014, 03:59
Vojtech Betak
betakv is on a distinguished road
You have mess in boundary conditions. For velocity you have to prescribe mass flow on inlet and zeroGradient/inletOutlet on outlet. For temperature is better to use adiabatic wall zeroGradient on the wall
adarsh tiwari likes this.
betakv is offline   Reply With Quote
Old   April 2, 2014, 14:45
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
http://www.cfd-online.com/Forums/ope...-get-help.html
kmooney is offline   Reply With Quote
Old   April 10, 2014, 02:25
Smile
adarsh tiwari
Thanks betakv and kmooney,
It solved the issue.
Best Regards,
Adarsh Tiwari
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX or Fluent for Turbo machinery ? Far FLUENT 3 May 27, 2011 03:02
how to make a CFX solution NITIN DEWANGAN CFX 2 August 8, 2008 08:06
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
