[mesh manipulation] objectRegistry error with Postprocessing Function Objects
Like Tree4Likes
  • 4 Post By iuginio
Old   March 3, 2014, 05:47
Default objectRegistry error with Postprocessing Function Objects
eugenio l
iuginio is on a distinguished road
I am a new OpenFoam user and I am simulating a valve with icoFoam solver.
The cylindrical housing is modelled with blockMesh followed by a double call to MirrorMesh, then the plate geometry is imported through .stl file and SnappyHexMesh.
The meshing process and the simulation worked fine.
Since I need to calculate the forces on the plate, I used the PostProcessing function Objects "forces", adding the corresponding entries in controlDict. With the introduction of these mirrorMesh reports an error:
|  \\    /   O peration     | Version:  2.3.0                                 |
Build  : 2.3.0-f5222ca19ce6
Exec   : mirrorMesh
Date   : Mar 03 2014
Time   : 11:10:47
Host   : "eugenio-desktop"
PID    : 7743
Case   : /home/eugenio/OpenFOAM/eugenio-2.3.0/run/tutorials/incompressible/icoFoam/checkValve_cylinderSnappy
nProcs : 1
Create time
--> FOAM FATAL ERROR:
    request for objectRegistry region0 from objectRegistry checkValve_cylinderSnappy failed
    available objects of type objectRegistry are
0()
    From function objectRegistry::lookupObject<Type>(const word&) const
    in file db/objectRegistry/objectRegistryTemplates.C at line 198.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::objectRegistry const& Foam::objectRegistry::lookupObject<Foam::objectRegistry>(Foam::word const&) const at ??:?
#3  Foam::OutputFilterFunctionObject<Foam::forces>::allocateFilter() at ??:?
#4  Foam::OutputFilterFunctionObject<Foam::forces>::start() at ??:?
#5  Foam::functionObjectList::read() at ??:?
#6  Foam::functionObjectList::timeSet() at ??:?
#7  Foam::Time::operator++() at Time.C:?
#8  Foam::Time::operator++(int) at ??:?
 at ??:?
#10  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#11
 at ??:?
Aborted (core dumped)
It seems to complain about "regions", but I haven't done any partitioning in my mesh domain. When excluding the entry "functions {..}" from controlDict and reintroducing it after the meshing process, the problem arises with the icoFoam solver.
Does anyone experienced a similar problem?
Thank you!
iuginio is offline   Reply With Quote
Old   March 4, 2014, 11:43
Smile
eugenio l
solved!
mirrorMesh -noFunctionObjects
Old   December 16, 2015, 06:21
chriss85 will become famous soon enough
Has anyone managed to get this working properly? I see the same error when I try to use this function object to calculate field averages in cellZones in a parallel case with a single region:
functions
bufferVolume
type cellSource;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputControl timeStep;
outputInterval 1;
log true; // log to screen?
valueOutput true; // Write values at run-time output times?
source cellZone; // cellZone or all
sourceName bufferVolume;
operation volAverage;
fields
p
I get the same error except for the case name. Does the solver need any special code to support function objects?
request for objectRegistry region0 from objectRegistry checkValve_cylinderSnappy failed available objects of type objectRegistry are 0()
Edit: If I add this to controlDict when the solver is already running it works for me.
chriss85 is offline   Reply With Quote
Old   June 28, 2021, 10:46
Default [volIntegrate] Unable to integrate over cellZone
Victor Baconnet
victor13165 is on a distinguished road
Hello everyone,
I stumbled upon the exact same problem, just wanted to ask again, maybe someone will be able to help in 2021
I am using interFoam to simulate wave breaking on coastal structures. To measure how much water has crossed a particular structure, I would like to calculate \int \alpha dV "downstream" of the structure, using the volFieldValue and the volIntegrate operation.
Because I only want to measure the volume of water in a type of sink downstream of the structure, I followed the documentation and added a new cellZone using topoSetDict :
         name    bacCellSet;
        type    cellSet;
        action  new;
        source  boxToCell;
        box     (21.6 -2 -2) (22.0 2 2); // Overall domain bounding box (-4 -0.01 0) (22 0.99 2)
        name    bac;   //This is the cellZone I will be using
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        set     bacCellSet;
I then specified that cellZone into the volFieldValue function objet in system/controlDict:
     waterVolume
        type            volFieldValue;
        libs            ("libfieldFunctionObjects.so");
        log             true;
        enabled         true;
        writeControl    timeStep;
        writeInterval   1;
        writeFields     true;
        regionType      cellZone;
        region          bac;
        operation       volIntegrate;
        fields
            alpha.water
However, when running the simulation, I get the following warning:
--> FOAM Warning :
    request for objectRegistry bac from objectRegistry isoADVECTOR_irreguliere_Tp9.5s_Hs2.8m_gamma1.0_N70_RAFFINE1processor0 failed
1(region0)
The highlighted part of the error message is my case directory name, but I found it weird that "processor0" was added right after it, instead of "/processor0", which would make it look more like a path.
I get the same error message when running in sequential (not in parallel).
I have no idea where this could come from, as I have never encountered the "objectRegistry" word before.
Cheers,
Victor
victor13165 is offline   Reply With Quote
Old   June 29, 2021, 17:03
Joachim Herb
jherb is on a distinguished road
I think, you problem is this line
region          bac;
Regions are used in the chtMultiRegionFoam solver. I think you want "name" or something else.
See e.g. https://github.com/OpenFOAM/OpenFOAM...oneAverage#L21
jherb is offline   Reply With Quote
Old   June 30, 2021, 03:45
Victor Baconnet
Thanks Joachim, using "name" worked perfectly.
I just checked the documentation (https://www.openfoam.com/documentati...ieldValue.html), it turns out "name" was the correct entry to use. I don't know how I came up with "region"...
Would not have been mad if I had received a RTFM...
functionobject, mirrormesh, objectregistry, openfoam 2.2.x
How to use the data generated by function objects at run-time? bigfeather OpenFOAM 1 November 1, 2016 05:55
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
