/opt/openfoam230/applications/test/mesh question....
Like Tree1Likes
  • 1 Post By blacksquirrel
Old   August 22, 2014, 21:00
Default /opt/openfoam230/applications/test/mesh question....
Freedom
wenxu is on a distinguished road
hello,everyone.
when i compile the /opt/openfoam230/applications/test/mesh (compile is ok), i have encountered the following error:
--> FOAM FATAL IO ERROR:
cannot find file
file: /opt/openfoam230/applications/test/mesh/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Anyone who can tell me what's wrong with it? please help me,thanks.
wen
wenxu is offline   Reply With Quote
Old   August 25, 2014, 10:44
blacksquirrel is on a distinguished road
Hi Wenxu,
in this folder /opt/openfoam230/applications/test/mesh is the source code of your program called Test-mesh (I have no idea what it does. What exactly do you want to do?)
To run the application Test-mesh, you need to make a case folder with system and constant subfolders.
Let me give you a simple example:
In /opt/openfoam230/applications/solvers/incompressible/icoFoam is the source code of the solver icoFoam, which you can compile.
Now you can use your solver with the command icoFoam in your case Folder
(e.g. /home/[user-2.3.0]/tutorials/incompressible/icoFoam/cavity)
squirrel
wyldckat likes this.
blacksquirrel is offline   Reply With Quote
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
question on bounday layer modeling Wen Long Main CFD Forum 2 November 12, 2005 17:29
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
