LES filter in OpenFOAM
Old   October 22, 2014, 17:09
Default LES filter in OpenFOAM
openfoammaofnepo is on a distinguished road
Dear All,
I would like to underatnd how the LES filters are implemented in OpenFOAM. For example, the most common one is simple filter, it is defined in:
simpleFilter.C and simpleFilter.H
The filtering operation for this option is like the following:
    tmp<volScalarField> filteredField = fvc::surfaceSum
        mesh().magSf()*fvc::interpolate(unFilteredField)
    )/fvc::surfaceSum(mesh().magSf());
So based on my understanding, this is very similar to an area averaging. Typically the filtered fields is always obtained from the integration with the filter kernel functions. But in openfoam, it seems that we did not see the appearence of the kernel functions. Does anybody know why the filters are implenementied like those in OpenFOAM?
Thank you very much.
openfoammaofnepo is offline   Reply With Quote
Old   October 23, 2014, 07:27
dkxls's Avatar
Armin
dkxls will become famous soon enough
This is nothing specific to OpenFOAM. It is generally related to the finite volume method (or actually to any discreet method).
I suggest you familiarize yourself with how the mathematical operators (like divergence, Laplacian, integral, ...) are implemented in a discrete world.
While there are many good books on CFD that cover that topic (e.g. Ferziger and Peric, 2002), I can recommend you the doctoral thesis by Jasak Hrvoje (http://powerlab.fsb.hr/ped/kturbo/Op...jeJasakPhD.pdf).
You will find there very detailed explanations on how these things are implemented in OpenFOAM.
References:
Ferziger, Joel Henry, and Milovan Peric. Computational Methods for Fluid Dynamics. 3rd ed., 2002. http://www.springer.com/materials/me...-3-540-42074-3.
dkxls is offline   Reply With Quote
how can use the LES filter? (laplace filter and anistropic filter) ethan oh OpenFOAM Running, Solving & CFD 11 December 26, 2018 02:37
Molecular viscosity calculation in LES on OpenFOAM babakflame OpenFOAM 0 January 26, 2014 04:13
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
LES with different filter Rick Main CFD Forum 1 August 22, 2008 18:10
