pressure spikes due to addition/deletion of layers |
October 25, 2011, 08:45 |
kshitij neroorkar
Rep Power: 17 |
Hello All
I was running icoDyMFoam on the tutorial case movingConeTopo. I added one line to icoDyMFoam to write out the maximum pressure in the domain at every time step. I found that almost every time there is a cell addition/deletion, there is a pressure spike in the domain. Has anyone else seen these spikes? and has anyone found a solution? Thanks Kshitij |
October 26, 2011, 03:48 |
Karl-Johan Nogenmyr
Rep Power: 21 |
Which version are you using? The implementation of the movingCone(or Body)TopoMesh is altered in later revisions of the 1.6-ext version. In the newer (and parallel) version, a lot of lines are commented out in Foam::movingBodyTopoFvMesh::update() . These lines affects how meshPhi (in fvc::makeAbsolute(phi, U) and fvc::makeRelative(phi, U)) is determined (if I understood correctly). If meshPhi is wrong, I would guess it could result in pressure peaks. Do you have any possibility to repeat your check on a previous, non-parallel version of the movingCone/Body case? Kalle |
October 27, 2011, 09:48 |
kshitij neroorkar
Rep Power: 17 |
Hi Kalle
Thanks for your post. We updated to the latest version of 1.6-ext to see what difference it made, and we found that the spikes were considerably smaller, but still existed. if you/ anyone else would like to test this, you can just add the following functionObject to the controlDict and run the movingConeTopo test case with icoDyMFoam. Thanks a lot for your help Kshitij functions{ fieldMinMax { type fieldMinMax; functionObjectLibs ("libfieldFunctionObjects.so"); log yes; outputControl timeStep; outputInterval 1; mode magnitude; fields ( U p ); } } |
October 28, 2011, 03:35 |
Karl-Johan Nogenmyr
Rep Power: 21 |
Thank you for bringing this up. I tried the case, and there are spikes as you say. Pressure is initially fluctuating around ~4e-4 to ~1e-4 as layerAR is working. I tried a few modifications to the movingBodyTopoFvMesh-class without success. Right now I do not have any clue how to get on. To solve this issue, I think one should find out how this adding layer functionality is handled within the finite volume method. This paper may provide some help: http://web.univ-ubs.fr/limatb/EG2M/D...pers/01178.pdf see especially section 2.3 I also need to fix this for my own work, so I will likely get back to it when I have time. Regards, Kalle |
October 28, 2011, 08:58 |
kshitij neroorkar
Rep Power: 17 |
Hi Kalle
Thanks for looking into this and thanks for the paper. Please let me know if you find anything. Kshitij |
November 29, 2014, 12:33 |
Jim
Rep Power: 12 |
I can see this thread is quite old, but I would like to know if this problem was ever resolved? I am having the same issue but with pimpleDyMFoam with layer addition/removal and translation (foam-extend 3.1). I have tried to resolve this by mostly messing around with the following settings, but with no real success: nCorrectors - increase nNonOrthogonalCorrectors - increase nOuterCorrectors - increase relaxation factor for pressure - reduce use of smoother & preconditioner with solver minimum layer thickness in dynamicMeshDict - increase Gauss upwind for div schemes and Guess linear limited for laplacian schemes zeroGradient for all pressures at boundary patches relTol for all solvers set to 0 Any advice would be greatly appreciated Thanks |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Pressure Condition | sidd | Siemens | 0 | April 2, 2007 09:31 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
