Problems when change the boundary conditions in rhoSimplicFoam tutorial example
Old   December 16, 2014, 08:52
Default Problems when change the boundary conditions in rhoSimplicFoam tutorial example
SylvainWang is on a distinguished road
Hello, Foamers;
I just begin to use OpenFOAM to do my thesis. Since my problem is a compressible case, so I'd like to choose the rhoSimplecFoam solver to solve it. In the tutorial example offered in the rhoSimplecFoam solver, it gives a mass flowrate inlet condition and pressure outlet condition. However, in my case, it should be a total pressure inlet condition and pressure outlet condition. Problem comes as I changed the boundary conditions of U and P after 3 iterations. The error messages are as following:
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:?
#4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
at ??:?
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Floating point exception (core dumped)
and the new boundary conditions are
P
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 100000;
boundaryField
    Default_Boundary_Region
        type            zeroGradient;
    inlet
        type            totalPressure;
        U               U;
        phi             phi;
        rho             none;
        psi             none;
        gamma           1.4;
        p0              uniform 200000;
    outlet
        type            inletOutlet;
        phi             phi;
        inletValue      uniform 100000;
        value           uniform 100000;
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
        type            fixedValue;
        value           uniform (0 0 0);
    inlet
        type            pressureInletVelocity;
        phi             phi;
        rho             rho;
    outlet
        type            pressureInletOutletVelocity;
        phi             phi;
The version I used is 2.3.0, from the error message, it seems that the errors comes from the thermal properties. Nevertheless, we should not encounter any errors when just change the velocity inlet boundary condition to a total pressure boundary condition. Is there any problems in the modified boundary conditions?
Endless appreciation if any foamers can help. Sylvain
SylvainWang is offline   Reply With Quote
Old   December 17, 2014, 15:43
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Sylvain,
I think you should change your pressure boundary condition for the outlet to either a fixed static pressure or to outletInlet instead of inletOutlet. Look up their differences in the sourcecode!
Some hints:
$> cd $FOAM_SRC
$> find . -iname *inletoutlet*
If you have a supersonic outlet, zeroGradient or waveTransmissive may be better options.
You may also need to ramp your total pressure at the inlet over several iterations. I think some examples may be found on the forum.
Regards,
Tom
tomf is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Boundary conditions for hassan hemida interFoam tutorial vishal_s OpenFOAM Pre-Processing 0 August 21, 2013 00:21
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
