Near Wall treatments in openfoam with refined mesh |
October 24, 2009, 09:59 |
Shui Pei
Rep Power: 17 |
Hi this is Pei, I am using k-epsilon model with default wall functions supported by openfoam, it seems when my mesh is coarse (10/unit lenghth) the result is quit good wcompared to the experiment. But after I increase the mesh desity to (30/unit length), the result changed and not fit the experiment.
I read some reference said the wall functions can only be used when the first point have a distance to the wall. Is there any treatments I can use in refined mesh with k-epsilon model? Another qustion is about edge grading , can I generate a edge like this . . . . ...... . . . . with blockMesh, now I can only use simple grading... Thank you very much. |
October 26, 2009, 17:27 |
Gavin Tabor
Rep Power: 17 |
For standard wall models to work you need y+>11.7 for the majority of the first cell to be in the log law region. If you can't manage this you probably need a low Reynolds number model like the Launder/Sharma low-Re k-e model.
On your second question, could you split the edge into two separate blocks?; |. . . . ..|.... . . . . | Gavin |
October 26, 2009, 20:57 |
#3 | |
Shui Pei
Rep Power: 17 |
June 1, 2015, 05:34 |
#4 | |
behzad Ghasemi
Rep Power: 12 |
i have same problem with grading and couldn't solve it. if you could solve this please help me too. i saw your modified blockMesh utility but it doesn't work on my OF versions.i tested on 1.6 ext,2.1.1,2.2.0 and 2.2.1. thanks in advance |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
salome, openfoam and moving mesh | prhlava | OpenFOAM Running, Solving & CFD | 8 | November 9, 2009 08:59 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
Harpoon and OpenFoam - Mesh and simpleFoam | scott | OpenFOAM | 4 | September 4, 2009 07:48 |
