interFoam - pressure explosion due to unknown reason
Old   June 4, 2015, 04:18
Default interFoam - pressure explosion due to unknown reason
aquamen
aquamen is on a distinguished road
Hey Guys,
My Simulation aborts before it ends with an undescribed ERROR.
After checking the Results, i found out, that a pressure"explosion" could be the reason. Does anyone of you know where this comes from??
http://www.picfront.org/d/9hKN
http://www.picfront.org/d/9hKO
Thanks for your help
aquamen is offline   Reply With Quote
Old   June 7, 2015, 06:32
Saideep
Saideep is on a distinguished road
hi there;
May be you can describe more about your case. I guess you are using someting like an interFoam solver?
Maybe your pressure might not be the reason. It is difficult to say unless you provide the conditions you are using.
But a best and simple way to know if you have an error is to proceed step wise from the available code and later modifying it step by step.
hope this helps;
Saideep
Saideep is offline   Reply With Quote
Old   June 10, 2015, 04:20
Default upload Simulation
aquamen
Hi
the easiest way is I give my Simulationparts.
You find it in the Attachments.
Please simulate it, and may you can tell me the problem for the Error.
Or even take a look on the files.
Thanks a lot
Old   August 25, 2015, 14:49
pingat is on a distinguished road
i'm not sure about that.
but do wallfunctions work with a zeroGradient in velocity? i don't know your case, but these parts should get inletoutlet at k and epsilon or a fixedvalue (0 0 0) in the U file.
pingat is offline   Reply With Quote
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
Setting up the pressure variation due to tornado in a duct(UDF)+animation guillaume1990 FLUENT 0 March 3, 2014 11:59
strange pressure behaviour with symmetricPlane boudary condition - interFoam duongquaphim OpenFOAM Running, Solving & CFD 10 August 20, 2013 14:00
Unexpected behavior for interFoam with fixedGradient pressure BC styleworker OpenFOAM Running, Solving & CFD 2 May 20, 2013 22:56
Pressure reference in cyclic interFoam AlmostSurelyRob OpenFOAM 7 February 16, 2011 09:58
