TVD schemes, questions about limitedLinear
Like Tree34Likes
Old   November 6, 2015, 06:11
Davi Barreira
davibarreira is on a distinguished road
There is Dr Jasak's thesis, which is a must for people using OpenFOAM (just google it and you will find right away). And also Versteeg and Malalasekera book on CFD.
davibarreira is offline   Reply With Quote
Old   October 25, 2018, 05:05
Default limited Linear NOT Sweby
  #22
Jan Gaertner
janGaertner is on a distinguished road
Hey,
I have seen in many posts, that limitedLinear uses the Sweby limiter function. This is not correct.
If you look at the code of the limitedLinear.H file you see:
scalar limiter
         const scalar cdWeight,
         const scalar faceFlux,
         const typename LimiterFunc::phiType& phiP,
         const typename LimiterFunc::phiType& phiN,
         const typename LimiterFunc::gradPhiType& gradcP,
         const typename LimiterFunc::gradPhiType& gradcN,
         const vector& d
     ) const
         scalar r = LimiterFunc::r
             faceFlux, phiP, phiN, gradcP, gradcN, d
         return max(min(twoByk_*r, 1), 0);
janGaertner is offline   Reply With Quote
Old   June 6, 2021, 16:18
s.v
s.v
s.v is on a distinguished road
Response to post #11 in this thread:
I am guessing the reason why "linear" and "limitedLinear 0" do not give identical results is because "limitedLinear 0" becomes upwind outside the Convection Boundedness Criterion (CBC) region on the NVD diagram -- see for example the discussion and figures around page 35 in my PhD thesis (https://drum.lib.umd.edu/handle/1903/21883).
Cheers ....
Tobi and anaspauzi like this.
Last edited by s.v; June 6, 2021 at 16:21. Reason: added which post I am responding to (post #11)
s.v is offline   Reply With Quote
Old   October 20, 2021, 10:36
Default A question of r
  #24
bany
bany is on a distinguished road
Originally Posted by jurich View Post
limitedLinear is used in fvSchemes as Gauss limitedLinear k
The value k you specify when activating the scheme is not the same as \psi, as used in Jasak's thesis.
What you get from limitedLinear is \psi(r) = r * \frac{2}{k}, with r as defined in Jasak's thesis, and \psi limited between 0 and 1.
See the discussion: http://www.cfd-online.com/Forums/ope...ar-scheme.html, and lines 76 and 95 of limitedLinear.H
So if you use k = 0, \psi will be fixed at 1.0, and you get the higher order scheme everywhere, in this case central differencing.
If you use k = 1, you get a limiter of \psi(r) = 2 * r applied. This limiter is the edge of Sweby's TVD region; it is TVD conforming.
That's why the documentation describes it that way.
Thanks for this explanation for \psi(r), where r=(phiC-phiU)/(phiD-phiC) defined in Dr. Jasak's thesis. Now i have two questions :
(1) If phiD-phiC=0, r equals? Just like the case:in a initial field, the value of phi (a scalar field) is uniform.
(2) As we know, r is related to the successive grad of phi. And C, D and U are at the upwind, downwind and far-upwind cells. While for the cells whose faces are at boundary, how does the definition of U and how does (phiC-phiU) calculate?
Any reply is grateful!
bany is offline   Reply With Quote
Old   October 20, 2021, 14:34
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
How do you examine the far-upwind cell in an unstructured FV mesh?
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   October 20, 2021, 21:00
Default 1D uniform structured mesh
  #26
bany
We only consider the simple condition: a 1-D structured FV mesh.
Old   October 20, 2021, 21:09
s.v
s.v
Tobi -- Jasak et al. discuss this point in their gamma scheme paper (https://citeseerx.ist.psu.edu/viewdo...=rep1&type=pdf) -- see for example the text below equation 10 in the paper -- they work with gradients ....
This link might also be useful -- https://www.openfoam.com/documentati...e-nvd-tvd.html
Old   October 20, 2021, 21:30
bany
Thanks for your reply. And when phiC=phiD, how to calculate r?
In my work: a 1D structured FV mesh, and the scalarField phi is uniform at the beginning. Thus phiC=phiD for initial time in every mesh.
When i output the matrix of convection term for the first timestep, i found the upper() and lower() of the matrix for convection term when using limitedLinear scheme is like that when using linear scheme. That means that when phiC=phiD, r=k/2. However, i failed to find the relative code in openfoam -- https://github.com/OpenFOAM/OpenFOAM...cheme/NVDTVD.H
Old   October 20, 2021, 21:43
s.v
s.v
Bany it has been a while since I looked at OpenFOAM ....
But I think the answer to your first question is in this file most likely -- https://www.openfoam.com/documentati...8H_source.html
It looks like if phiD-phiC=0 (I think in the file above they call phiD as phiN and phiC as phiP) the following lines in the above file will come into play:
if (mag(gradcf) >= 1000*mag(gradf))
return 2*1000*sign(gradcf)*sign(gradf) - 1;
which means r will either become 1999 or -2001 if phiD-phiC=0 or phiN-phiP=0 depending upon the signs of the gradients ....
Regarding your second question -- see my response to Tobi above -- they work with gradients -- they don't explicitly use the far-upwind cell ....
Again I have been away from OpenFOAM for a while -- but most likely what I have said above should be OK ....
Also remember that the gamma and limitedLinear schemes are very similar -- the only difference is how they switch between upwind and linear schemes -- if we use the factor "k" equal to 1 then gamma scheme switches more smoothly compared to limitedLinear scheme (see for example figure 2.9 in my thesis -- download link given above in one of my other posts) -- if we use a smaller value of the factor "k" like 0.2 then both schemes become pretty much the same (see figure 2.10 in my thesis) .... also note that the gamma scheme is generally bugged in OpenFOAM (this is also briefly discussed in my thesis) -- so I plot the dbGamma scheme in figures 2.9 and 2.10 -- dbGamma basically means debugged gamma scheme -- thats the best name I could come up with for my thesis ....
Old   October 20, 2021, 21:53
s.v
s.v
Bany -- for limitedLinear to behave like linear scheme r does not need to be exactly = k/2 ....
https://github.com/OpenFOAM/OpenFOAM...imitedLinear.H
At the end of the above file we see:
so if r = 1999 like I mentioned in my other post -- the above line will return 1 -- and for a value of 1 -- limitedLinear will behave like linear I think .... the above line is returning \psi(r) in the TVD framework I think .... sorry I do not know how to use math in these posts yet ....
Old   October 20, 2021, 22:58
bany
Oh, what you said helped me a lot and your thesis is so clearly. Thank you very much.
For the second question, the gradients are used. For the cell near the boundary just like the cell C in figure. The gradient of phi for the cell C is calculated by following: grad(phiC)=(phiC-phib)/(XC-Xb), where phib is the value of phi on the boundary.
If something is wrong, please note that.
Old   October 20, 2021, 23:05
bany
Yeah, you are right. If r >= k/2, limitedLinear will equal to linear. Thanks again.
For the math scheme, you can quote any posts included math scheme and you will see the original math code. Just like: "[ math]......[ /math]" (of course, there is no space in [].). And \psi is "[math ]\psi[/math ]" in math scheme.
A few simple questions about linearUpwind and limitedLinear chegdan OpenFOAM 28 March 30, 2024 02:44
Using TVD Schemes in fvScheme aydemirk OpenFOAM Pre-Processing 1 August 20, 2014 04:26
TVD schemes Vino Main CFD Forum 3 September 16, 2013 19:47
TVD schemes: 2 questions Shuo Main CFD Forum 0 August 19, 2008 21:51
TVD Schemes Matt Umbel Main CFD Forum 1 January 25, 2000 04:21
