Advice on simulating gas filternig system
Old   December 14, 2015, 17:47
Default Advice on simulating gas filternig system
a99
Kohbodi
a99 is on a distinguished road
Hi everyone,
Basically I am looking so simulate gas filtering through a liquid based on the pressure applied. You can imagine this as a scrubber system (air pollution control devices) hookahs, inhalers, etc...
I am using OpenFoam and pretty new to it but have a solid grasp of it. I was thinking of using similar to interFoam? Not sure how I can simulate pressure applied causing air to go through the liquid (bubbling, filtering?).
Are there previous work on this topic through the use of OpenFoam? Should I use Ansys Fluent in this case? Any help is much appreciated.
Thank you
a99 is offline   Reply With Quote
Old   December 14, 2015, 22:27
Cyp
Cyprien
Cyp is on a distinguished road
There is no magic in CFD. You first have to define the PDE you want to solve. Then you can start to discuss the tool, not before. First thing first.
Cyp is offline   Reply With Quote
Old   December 15, 2015, 00:04
a99
Kohbodi
Thank you for you answer.
I understand the PDEs involved. I will most likely be using OpenFoam, my question was any tips in regards of what solver can handle this scenario best.
But good to know there is no magic in CFD.
Gas-Liquid System frenk_8 Main CFD Forum 0 June 18, 2014 05:05
Need advice on softwares working for dilute gas flow Mason Main CFD Forum 4 July 22, 2010 15:55
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
allowed gas phase escape Abu-Khawlah FLUENT 0 August 20, 2005 10:14
advice needed in solving linear system yf yap Main CFD Forum 5 February 5, 2001 00:21
