looking for the step-by-step tutorial of chtMultiRegionSimpleFoam/heatExchanger |
January 6, 2016, 06:14 |
Dear All,
Sorry for the new thread. I have a mesh for shell and tube heat exchangers in *.msh format. I have imported this to OpenFOAM 231. all the walls are having zero thickness. With some literature survey, i learned, chtMultiRegionSimpleFoam will be of suitable for this case. I have searched the forum and some links on google, but unfortunately not got any satisfactory answers. Code:
http://www.cfd-online.com/Forums/openfoam-pre-processing/126581-chtmultiregionsimplefoam-tutorial-heatexchanger.html http://www.cfd-online.com/Forums/openfoam-solving/164200-using-functionobjects-chtmultiregionsimplefoam.html http://www.cfd-online.com/Forums/openfoam-paraview/121666-post-processing-heatexchanger-chtmultiregionsimplefoam.html http://www.cfd-online.com/Forums/openfoam-solving/126777-chtmultiregionsimplefoam-heat-source-not-boundary.html Code:
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2012/MaaikeVanDerTempel/chtMultiRegionSimpleBoussinesqFoam7.pdf http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2010/alirezaJavidi/alirezaReport.pdf Kindly help me in simulating this custom made shell and tube heat exchanger. Thanks in advance. With best regards, Adarsh |
January 26, 2016, 21:11 |
Alex
Rep Power: 21 |
Hi Adarsh,
My recomendation, if your goal is to learn to set up a chtMultiRegion*Foam case, is to take a strong look at the planeWall2D tutorial. There you will find the answers to all your questions about this solver! After that you will be able to understand what is behind the heatExchanger tutorial. Hope it helps. Best regards, Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
May 13, 2017, 20:11 |
alberto
Rep Power: 10 |
Hi, did you find some tutorial about this?
May 16, 2017, 18:16 |
Tobias Holzmann
Rep Power: 51 |
I just can suggest the one I made on www.holzmann-cfd.de
The tutorial mentioned in the wiki page is not working properly. Bruno already told me to fix it but it is not as trivial as one thinks and to be honest, there is no time
Keep foaming, Tobias Holzmann |
May 18, 2017, 11:30 |
#5 | |
alberto
Rep Power: 10 |
Could you help me with something? When i run the heatExchanger simulation tutorial and finished, I tried to open the results and i got this error: terofluidos@Cascabel:~/Documentos/openfoam/tutorials/heatTransfer/chtMultiRegionSimpleFoam/heatExchanger$ paraFoam ERROR: In /home/ubuntu/OpenFOAM/OpenFOAM-4.1/applications/utilities/postProcessing/graphics/PVReaders/PVFoamReader/PVFoamReader/vtkPVFoamReader.cxx, line 216 vtkPVFoamReader (0x37d0b10): could not find valid OpenFOAM mesh ERROR: In /home/openfoam/OpenFOAM/ParaView-5.0.1/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkPVCompositeDataPipeline (0x212cd60): Algorithm vtkPVFoamReader(0x37d0b10) returned failure for request: vtkInformation (0x37d1980) Debug: Off Modified Time: 162970 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 ERROR: In /home/ubuntu/OpenFOAM/OpenFOAM-4.1/applications/utilities/postProcessing/graphics/PVReaders/PVFoamReader/PVFoamReader/vtkPVFoamReader.cxx, line 216 vtkPVFoamReader (0x37d0b10): could not find valid OpenFOAM mesh ERROR: In /home/openfoam/OpenFOAM/ParaView-5.0.1/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkPVCompositeDataPipeline (0x212cd60): Algorithm vtkPVFoamReader(0x37d0b10) returned failure for request: vtkInformation (0x37d1980) Debug: Off Modified Time: 162970 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 |
May 18, 2017, 11:33 |
#6 | |
alberto
Rep Power: 10 |
is there something that i am ommitting? Thank you for your time. |
May 18, 2017, 11:43 |
Tobias Holzmann
Rep Power: 51 |
What is if you make a empty file named paraview.foam and load paraview and load that file? Does the same error occur? Did the solver finished without any problems? Sometimes I have the problem that I abort a simulation while it was writing results. Then the result files are destroyed and I have to remove the latest one.
May 18, 2017, 11:56 |
alberto
Rep Power: 10 |
Forget it! I could find the solution.
I was writing only the command paraFoam instance of paraFoam -builtin. But thank you for all the tutorials! |
May 19, 2017, 14:21 |
#9 |
alberto
Rep Power: 10 |
Hi tobi, sorry to bother you
I want to simulate flow through one pipe, with two obstacles, this obstacles are inmersed like in the figure. 1.- I export with .msh 2.- splitMeshRegions -cellZones -overwrite (fluid, porosity, solid) i got this : porosity_to_part_4-solid { type mappedWall; inGroups 1(wall); nFaces 24192; startFace 1479713; sampleMode nearestPatchFace; sampleRegion part_4-solid; samplePatch part_4-solid_to_porosity; } This separate my three domains, but the interior faces of my porosity became into wall. I want the fluid flow through the porous media. how can i fix this? In the heatexchanger tutorial they consider walls in the porous medium. Thank you. |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
bubbleFoam tutorial case with turbulence | setzberg | OpenFOAM Running, Solving & CFD | 6 | October 15, 2015 13:29 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
