Dissimilar meshes with chtMultiRegionFoam
Old   September 19, 2011, 21:51
Default Dissimilar meshes with chtMultiRegionFoam
Charles McCreary
crmccreary is on a distinguished road
I've been using chtMultiRegionFoam with good success for some time now. To date, all of the cases I've solved have been "consistent" meshes in that the solid/fluid interface patches share the same points. Is there a mechanism in OpenFOAM in which I can use completely different meshes for the solid and the fluid in which no points are shared?
My objective is to have a rather coarse mesh for the solid and a very fine mesh for the surrounding fluid.
crmccreary is offline   Reply With Quote
Old   September 21, 2011, 03:03
Aram Amouzandeh
mabinty is on a distinguished road
thats a very good question I d be also interested in! what I m currently trying is to refine the base mesh where later on the individual regions should be placed in order to achieve different mesh sizes in the regions.
aram
mabinty is offline   Reply With Quote
Old   September 21, 2011, 08:34
Vesselin Krastev
vkrastev is on a distinguished road
The chtMultiRegionFoam (and chtMultiRegionSimpleFoam as well) solver implemented in the OpenCFD OpenFOAM releases (at least till the 1.7.1 one) needs a consistent mesh at the separation surface between different regions. By the way, I saw recently a presentation from Prof. Jasak in which he explained quite clearly that the GGI (Generic Grid Interface) implemented in the -dev or -ext OpenFOAM releases is (in principle) capable of handling any type of flux exchange between two adiacent non-conformal interfaces: thus, if you are interested in this topic, I can advice you to deeply investigate the capabilities of the OpenFOAM-1.6-ext release (personally I havent't had sufficient time to do it in the last period, so I will not be able to give you any practical further support about this matter).
Regards
V.
vkrastev is offline   Reply With Quote
Old   September 21, 2011, 15:02
MSR CHANDRA MURTHY
chandramurthy is on a distinguished road
It must be possible with ggi feature of 1.6-ext. The non-conformal fluid-solid coupled BC need to be conservative and at-least 2nd order accurate to get better results. I think it can work out, if you can write a new BC inheriting the classes of ggi and coupled bc of chtmultiregionfoam. It appears that the present implementation of ggi in 1.6-ext is conservative due to face-cutting method. I think it is possible to implement it.
I have done a similar type work, which takes the nearest 3 points and calculates new face field using inverse distance weight function method. hope this is useful
regards,
Chandra Murthy
chandramurthy is offline   Reply With Quote
Old   February 9, 2016, 06:49
Peng Liang
tjliang is on a distinguished road
Could anyone tell me if it is possible to use dynamic mesh refinement in fluid region in chtmultiregionfoam . If yes, could someone tell me how.
Bests ,
Peng
tjliang is offline   Reply With Quote
Old   February 12, 2016, 03:26
hcl734 is on a distinguished road
I don't know about dynamic mesh refinement but to answer the original question of this thread.
It is possible to use arbitrary mesh interfaces by using nearestPatchFaceAMI as boundary type between solid and fluid.
hcl734 is offline   Reply With Quote
Old   February 12, 2016, 04:07
Also take a look at this
http://www.cfd-online.com/Forums/ope...-openfoam.html
[Technical] Automatic Mesh Refinement and Tetrahedral Meshes philippose OpenFOAM Meshing & Mesh Conversion 8 May 21, 2016 15:44
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 07:06
Dynamic Meshes Cfdtoy FLUENT 2 February 6, 2004 12:14
Merging Meshes Matteo Giacobello. FLUENT 1 February 16, 2000 09:22
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
