Need help in airfoil simulation by OpenFOAM
Old   November 17, 2018, 00:42
Default Need help in airfoil simulation by OpenFOAM
kevin
kevin.pku is on a distinguished road
Hello everyone,
I am a new guy in OpenFOAM. I did a 2D airfoil simulation by OpenFOAM. Unfortunately, the airfoil drag coefficient from the simulation is negative, this
is unphyiscal. I tried my best but still can not find the reason. It may be
caused by the mesh generation, case setup, or postprocessing setup. Could anyone help me? Thank you.
1. The mesh of the airfoil is a C-Mesh. In order to run the .msh file in OpenFOAM, I extrude the 2D airfoil mesh to 3D, in which I keep the boundary setup of OUTFLOW, WALL and FRONTANDBACK, but remove the INLET.
2. The setup of the initial velocity and pressure in the 0/U file is as follows:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (6.894 1.216 0);
boundaryField
OUTFLOW
type freestream;
freestreamValue uniform (6.894 1.216 0);
FRONTANDBACK
type empty;
WALL
type noSlip;
3. The AoA is 10 deg, and the initial Re is about 1e+7.
4. The setup of function for calculating force coefficients in the system/controlDict file is as follows
functions
forceCoeffs
type forceCoeffs;
functionObjectLibs ("libforces.so");
patches (wall);
log true;
rho rhoInf;
rhoInf 1;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 1);
magUInf 7;
lRef 1;
Aref 1;
writeControl timeStep;
writeInteval 100;
5. The results of Cm, Cd, Cl are as follows
Cm = 4.613587e-01
Cd = -1.192186e-01
Cl = 1.315706e+00
kevin.pku is offline   Reply With Quote
Old   November 18, 2018, 12:43
Zander Meiring
yambanshee is on a distinguished road
How large is your C diameter in relation to the chord length of the blade?
How 'converged' is your result?
What does your streamlines over the blade look like?
yambanshee is offline   Reply With Quote
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
Airfoil 2D cfd simulation Cocorito90 OpenFOAM Running, Solving & CFD 14 December 19, 2016 03:43
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFoam Airfoil simulation - replacing Fluent with OpenFOAM shereez234 OpenFOAM Running, Solving & CFD 1 November 3, 2015 03:54
Airfoil simulation using moving wall Alejandro Fidelity CFD 9 November 4, 2008 02:00
