compilation problem of gamma-ReThetatSST transition model |
May 12, 2016, 19:13 |
Rep Power: 10 |
Hi Foamers,
i can't compile the transition model gamma-ReThetatSST downloaded from here: https://github.com/langfeldt/gammaReThetatSST i have this error message: gianmichele@gianmichele-K52Jc:~/OpenFOAM/gianmichele-3.0.1/gammaReThetatSST-master/src/turbulenceModels/incompressible/RAS$ wmake libso g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/turbulenceModels -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/turbulenceModels/incompressible/RAS/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c gammaReThetatSST/gammaReThetatSST.C -o Make/linux64GccDPInt32Opt/gammaReThetatSST/gammaReThetatSST.o gammaReThetatSST/gammaReThetatSST.C:30:49: fatal error: backwardsCompatibilityWallFunctions.H: File o directory non esistente #include "backwardsCompatibilityWallFunctions.H" ^ compilation terminated. make: *** [Make/linux64GccDPInt32Opt/gammaReThetatSST/gammaReThetatSST.o] Errore 1 Before i had same error but for absence of other dictionaries that i have added in lnInclude but now i haven't found this file backwardsCompatibilityWallFunctions.H in OpenFOAM directories. Someone could help me to find this? |
November 3, 2017, 05:45 |
#2 | |
SAM
Rep Power: 14 |
Hi Dear
Did you figure this out? I have the same problem and will be grateful if you share your solution. Regards Quote:
Gamma ReTheta Transition Model | arkadu | Siemens | 2 | April 13, 2018 17:30 |
Question regarding Gamma Re Theta Model | CFXstudent26 | CFX | 9 | May 15, 2014 13:59 |
problem in gamma-retheta transition model | mb.pejvak | Main CFD Forum | 0 | November 25, 2012 01:48 |
problem with MFR model for multiphase mixing tanks | Srinivas | Main CFD Forum | 1 | November 7, 2005 14:16 |
