Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Time average pressure field after finishing calculation
Old   May 30, 2016, 04:52
Default Time average pressure field after finishing calculation
DongHo
eddykendo is on a distinguished road
Hi, Foamers
I want to get time averaged pressure distribution for a certain time duration (for instance, t=0.4 to 0.5 for total simulation time 1.0) on the surface of a cylinder after completing a calculation by URANS with k-kl-omgega model.
I know that the instantaneous pressure distribution on the surface of the cylinder at each time step can be easily attained using "plot on intersection curves". However, as mentioned above, what is the easiest way to get the time averaged pressure distribution on the surface of the cylinder for a certain time duration using OpenFOAM itself or Paraview?
I will appreciate it if you can let me know that.
eddykendo is offline   Reply With Quote
Old   April 23, 2017, 21:12
subhankar
SUBHANKAR is on a distinguished road
Hi DongHo,
I am facing a similar problem. If you have solved your problem can you please tell me how you did it?
Thanks and regards
Subhankar
SUBHANKAR is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
