June 9, 2016, 14:51 |
parallel custom made code
Evangelos
Rep Power: 14 |
Hello !
i write a routine in paramagnetic force and i want to parallel the code. i use icouncoupled combined with icofoam to simulate the motion of particles. It seems that i can't simulate many particles because of the time that dipole dipole forces are solved (74 sec 300 particles timestep = 1e-9) Is there any tutorial ? |
June 13, 2016, 18:45 |
Thomas Oliveira
Rep Power: 12 |
Does your routine operates in a cell at a time, or does it involve many cells in a single calculation?
April 25, 2017, 06:14 |
Evangelos
Rep Power: 14 |
April 25, 2017, 07:32 |
Thomas Oliveira
Rep Power: 12 |
If you write call your routine from inside a pre-existing loop such as icoFoam's "while (runTime.loop()){...}" it should normally inherit the parallelization that is already implemented in OpenFOAM. By this I mean that your routine will be called simultaneously for each subdomain of your mesh. Isn't it the case for you? Do you want to parallelize it further?
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
How to run custom solvers in parallel (CLUSTER) ? | iy-a | OpenFOAM Running, Solving & CFD | 0 | August 3, 2015 06:45 |
2D code in slip regim of parallel plates | RamRam | Main CFD Forum | 0 | November 20, 2011 04:43 |
Problems with MFIX code and Parallel Processing. | Fernando Pio | Main CFD Forum | 4 | August 29, 2006 14:33 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
