Quick navigation of source code etags definition
Old   December 28, 2008, 17:05
Default Anyone here uses emacs + etags
M. Jensen
newsboost is on a distinguished road
Anyone here uses emacs + etags on source code files? Or perhaps there's another tool than etags, that can be used?
The reason to use such tools is for quickly navigating to program code definitions like it is possible in visual studio under windows.
I think one needs to go to ~/OpenFOAM/OpenFOAM-1.5.x/src and type something like:
find . -name "*.[chCH]" -print | | etags -
to create the tags table. Is this right, and is there anything else to consider or know about?
Would this be all that's required or necessary for quickly jumping around, i.e. see class definitions?
newsboost is offline   Reply With Quote
Old   December 28, 2008, 19:35
Default I use Netbeans to do it. There
Sandeep Menon
deepsterblue will become famous soon enough
I use Netbeans to do it. There's a openFoamWiki article about setting it all up.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   December 29, 2008, 02:22
Default Hi, I use cscope, but not f
Fabian Braennstroem
braennstroem is on a distinguished road
I use cscope, but not frequently (yet) ...
http://cscope.sourceforge.net/
http://meditate.pdl.cmu.edu/pdl-emacs-talk-20040608.pdf
Try xcscope.el and ascope.el
Fabian
braennstroem is offline   Reply With Quote
Old   December 29, 2008, 19:19
Default Hi, Thanks both... I don't
M. Jensen
Thanks both... I don't like netbeans, kdevelop and eclipse but I got emacs working with cscope:
download latest:
http://cscope.sourceforge.net/#downloads
I already got cscope installed as part of my distro, therefore: As I remember it, I took these 2 files (from contrib-dir) and placed them here:
/usr/local/bin/cscope-indexer (chmod +x)
/usr/share/emacs/22.2/lisp/xcscope.el
(where /usr/share/emacs/22.2 is emacs load path)
Then I added to .emacs:
(setq cscope-do-not-update-database t)
;;(load-file "/usr/share/emacs/22.2/lisp/xcscope.el")
(require 'xcscope)
Not sure about what 2nd line does, I think third line does the same, anyway it seem to work the same whether or not 2nd line is commented or not.
Then I went to ~/OpenFOAM/ and ran (build database recursively, not sure if "q" for quick indexing works):
cscope -R -q -b &
And everything seem to work... I'm happy about this, I can quickly dig into symbols and files.
Thanks again, if you have any comments or ideas please let me know.
Surface reaction source definition. windhair CFX 0 March 17, 2008 05:36
Definition of point source George Siemens 0 February 22, 2007 04:19
Please help me run UDF code for source Suga FLUENT 1 February 3, 2006 03:40
2D ALE Source Code Shukla Main CFD Forum 5 October 27, 2005 00:44
SIMPLE/QUICK source code Ray Main CFD Forum 7 May 1, 2001 12:32
