Time directories
Old   May 20, 2008, 04:10
Default Hi all, I'm new in using Op
Roberto
robbo is on a distinguished road
Hi all,
I'm new in using OpenFOAM and I have a little question to you all, hopefully anyone could give me the right answer.
Why OpenFOAM stores the solution of the field in time directories even if the problem is steady? It is becuse it uses a time-marching approach?
Thanks in adance for your help
Robbo
robbo is offline   Reply With Quote
Old   May 21, 2008, 16:49
Default For steady state solvers chang
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
For steady state solvers changing the time step will have absolutely no effect on the solution. It will only change the output directory names. There is no time-marching approach in the steady solvers to my knowledge. Think of each 'Time' instance as one iteration. Maybe someone else can confirm this.
So to answer your question (Why OpenFOAM stores the solution of the field in time directories even if the problem is steady?), I think the reason for the same is consistency between both transient and steady solvers so that tools like foamLog can expect the same format when extracting data from log files. That is just one reason I could think off the top of my head. Rest assured, you can always play with the under-relaxation factors when using SIMPLE by tuning them in one of the dictionary files.
msrinath80 is offline   Reply With Quote
Modifying Source Files in Flow3D Directories Xizao Yang FLOW-3D 3 January 15, 2009 03:02
OFstream doesnbt create directories or throw errors brooksmoses OpenFOAM 3 January 30, 2006 06:28
Script for generating lnInclude directories brooksmoses OpenFOAM 4 January 26, 2006 19:02
Modify the reconstructPar to delete the reconstructed parallel directories within the loop maka OpenFOAM Post-Processing 2 December 16, 2005 10:37
Modifing reconstructPar to delete the reconstructed parallel directories maka OpenFOAM Pre-Processing 1 December 13, 2005 07:16
