Calculus syntax
Old   April 28, 2006, 12:25
Default I am wondering if some is able
chris book
chris1980 is on a distinguished road
I am wondering if some is able to "translate" me the code in a more mathematican way.
phi = fvc::interpolate(rho)
*((fvc::interpolate(U) & mesh.Sf()) - fvc::meshPhi(rho, U));
> what is phi in this context? I do not understand how it is computed!
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::ddt(psi, p)
+ fvc::div(phi)
- fvm::laplacian(rho*rUA, p)
>How to determine this equation? I think this is PISO related stuff.
pEqn.solve();
chris1980 is offline   Reply With Quote
Old   April 29, 2006, 09:26
Default Hi Chris, in foam usually a
Markus Hartinger
hartinger is on a distinguished road
Hi Chris,
in foam usually all variables are stored at the cell centre. But for calculating the divergence of a field the face values are needed. So fvc::interpolate returns a field containing the face values interpolated from the cell-centre values. The interpolation scheme is defined in system/fvScheme by the entry interpolationScheme, usually linear.
phi is in your example the mass-flux across the faces corrected for mesh-motion by fvc::meshPhi.
the pEqn is part of PISO, probably you look in one of the foam thesis' for it's derivation or ferziger and peric
regards
Markus
hartinger is offline   Reply With Quote
Param. & calculus in Fluent's Journal: Possible ? Kiril FLUENT 0 August 24, 2006 09:12
Syntax r2d2 OpenFOAM 1 December 13, 2005 13:19
Syntax What does mean evgenii OpenFOAM Pre-Processing 2 November 23, 2005 08:42
Syntax changes between versions 1.0.x and 1.1 OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 11, 2005 11:48
mesh and calculus servicies ro-design team Main CFD Forum 0 March 7, 2005 05:14
