Critical errors during OpenFoam installation in OpenSuse 11.0
Old   April 22, 2009, 10:51
Default Critical errors during OpenFoam installation in OpenSuse 11.0
Alexandre M S Costa
amscosta is on a distinguished road
Dear Group,
I am trying to install OpenFOAM in a OpenSuse 11.1 system pc.
However I am getting the following :
Executing /home/amscosta/OpenFOAM/OpenFOAM-1.5/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: pcu-95588
OS: Linux version 2.6.27.7-9-default
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/amscosta/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/amscosta/OpenFOAM/amscosta-1.5 yes no
$WM_THIRD_PARTY_DIR /home/amscosta/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/amscosta/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR ...amscosta/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...OAM/amscosta-1.5/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version : ../configure
4.3.2
Minimum required: 4.2.0
gcc ...figure
WARNING: Conflicting installations:
OpenFOAM settings : /home/amscosta/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /usr/bin/gzip
tar 1.20 /bin/tar
icoFoam
OpenFOAM settings : /home/amscosta/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Checking networking...
Action Result Crit
Pinging_pcu-95588 Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
Any guideline is very welcome.
Thanks,
Alex
amscosta is offline   Reply With Quote
Old   April 27, 2009, 10:40
Henrik Rusche
henrik is on a distinguished road
Dear Alex,
I have a same messages, but OpenFOAM runs nicely on my machine for quite a while. So give it a try.
Henrik
henrik is offline   Reply With Quote
Old   April 30, 2009, 17:08
Default Reply
Alexandre M S Costa
Thanks for the encouragement.
I started the following :
  • cd $HOME/OpenFOAM/$USER-$WM_PROJECT_VERSION/run/tutorials/icoFoam/cavity
  • blockMesh
  • icoFoam
  • paraFoam
However I get a message from the first : blockMesh command not found.
Where they are located ?
Thanks,
Alex
Old   April 30, 2009, 18:00
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Hi Alex,
/home/.../OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/blockMesh
-Louis
louisgag is offline   Reply With Quote
Old   May 1, 2009, 09:28
Default Folder empty
Alexandre M S Costa
Thanks again,
the directory is empty : amscosta@linux-m6bp:~/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt> ls
If I start following another approach what should be the best linux version to
start with OpenFOAM, i.e., with less incompatibility problems ?
Alex
Old   May 1, 2009, 14:06
louisgag's Avatar
Louis Gagnon
if the directory is empty it might be due to improperly decompressed files (tar -xvvf filename) or to having the improper version (ie 32 instead of 64 bits)
as for the best version of linux I am clueless as the only one i personally used is ubuntu...
good luck,
-Louis
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Critical errors gcc and icoFoam during installation of 15 quartzian OpenFOAM Installation 3 December 12, 2008 12:42
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
