March 5, 2011, 11:49 |
Calculator after GroupDatasets doesn't work
Hey,
I'm using ParaView 3.8.1 64bit for my studies and read some ASCII tecplot files with several timesteps and scalar value Z. First of all I use the filter "TemporalStatistics" and generate a standard deviation of Z. Then I want to use Z and Z_stddev within the calculator. There's only the possibilitie to choose both values on the dropdown menu "Scalars" when I made a GroupDataset of my tecplot-file and the TemporalStatistics before. But when I apply to the calculator, unfortunately I receive an error "expeting a variable name" every time. Isn't it possible to use the calculator after GroupDatasets, using variables that have been calculated withing the datasets? Thanks a lot for your help! Kind regards Hunky |
How to work with constant pressure? | Martin | Siemens | 2 | February 25, 2009 13:23 |
Getting FoamX to work | shaun | OpenFOAM Installation | 12 | March 23, 2007 08:55 |
work related to brake study of a vehical | aero | Siemens | 3 | November 23, 2006 07:43 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
