Wall function help!
Old   February 21, 2011, 14:52
Question Wall function help!
Ammar Tareen
atareen64 is on a distinguished road
Dear Foamers,
Basic setup: I am passing fluid through a laval nozzle and I expect the velocity to exceeded Mach 1, so I decided to use the K-epsilon model for my simulation; my solver is sonicFoam. The thermophysical properties for my fluid are as follows:
thermoType ePsiThermo<pureMixture<polynomialTransport2<specie Thermo<eConstThermo<perfectGas>>>>>;
mixture KrHe // 20%helium-80%krypton mixture.
1 //nMoles (??)
69.04 //molecular weight [kg/kmol]
1041.8 // heat capacity [K/kgK]
0.0 //standard formation enthalpy [J/kg]
muPolynomial (1.27906e-005 4.61187e-008) //dynamic viscosity [kg/ms]
kappaPolynomial (0.0406885 0.000146747); //heat conductivity [W/mK]
(here the viscosity and heat conductivity are linear temperature-dependant polynomials)
Confusion: As you can see from the mupolynomial, I want the magnitude of the viscosity to be somewhere around the 10e-5 range. However, because I am using the k-e model there is a mut file in the 0 directory andI am afraid that this mut file is causing the viscosity to be higher than I actually want in my simulation. The value of mut is some around 10e-2. The contents of 0/mut are as follows:
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object mut;
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 0;
boundaryField
inle2
type calculated;
value uniform 0;
outl3
type calculated;
value uniform 0;
wall1
type mutWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
frontAndBack
type empty;
Need your help:
I don't quite understand what the mut file is for? Shouldn't muPolynomial in my thermophysical properties be sufficient for specifying the viscosity?
Ideally I want the viscosity to be specified by my thermoPhysical properties dictionary only and I don't want a mut file, in fact I don't even understand what it is for or what a wall function means. Can some body please please please help me or give me some advice?
Best regards,
Ammar.
atareen64 is offline   Reply With Quote
Old   February 22, 2011, 12:46
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Read up on law of the wall and wall models/functions on the CFD Wiki:
http://www.cfd-online.com/Wiki/Law_of_the_wall
http://www.cfd-online.com/Wiki/Wall_functions
If you have a wall in your domain and you are running turbulent simulation, you need to specify wall functions or else your simulation isn't going to make sense.
Your simulation should be using whatever is in your thermoPhysical properties file. Calculated boundary conditions mean nothing; they simply show what the calculated value for a variable is for the particular timestep. Only boundary conditions like fixedValue, zeroGradient (basically anthing in finiteVolume/fields/fvPatchFields and similar) will affect your simulation.
Hope this helps.
mturcios777 is offline   Reply With Quote
Old   February 22, 2011, 12:48
Ammar Tareen
Thanks soo much!
k-e model, viscosity, wallfunction
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Need some wall function approaches! yka8150 Main CFD Forum 0 September 21, 2009 23:08
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
Wall function tod Phoenics 1 May 19, 2003 05:05
