Working in parallel with OpenFoam
Old   July 6, 2009, 09:27
Default Working in parallel with OpenFoam
Dr. Fabian Schlegel
fs82 is on a distinguished road
I have some cases running on a High Performance Computer (SGI Altix 4700) in parallel with 16 CPUs. They produce a large amount of foam time directories. I need this time directories for checking my case during run but in the end I only need the time directories over a period of time. So my question: Is there any tool or any option of a tool which allows me to delete a huge amount of data in every processor* directory? Doing this by hand is to time expensive for me. May be I can tell reconstructPar to reconstruct more than one time directory and delete the processor* directories?
thx for help,
fs82
fs82 is offline   Reply With Quote
Old   July 6, 2009, 09:53
Etienne Lorriaux
elorriaux is on a distinguished road
I think you are searching after the writeCOntrol, purgeWrite and writeInterval keywords in the controDict.
Regards, Etienne.
elorriaux is offline   Reply With Quote
Old   July 6, 2009, 09:57
Dr. Fabian Schlegel
No, I know this possibility. But I want to keep the time directories until my run is finished, e.g. for error searching.
Old   July 6, 2009, 10:13
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Fabian
Then I would suggest that you make some kind of shell script to run through the time directories. It could be something like this (warning, not tested)
#!/usr/bin/bash
list=`ls -d processor0/*`
listP=`ls -d processor*`
# this limit should be any of you liking, i.e. time step
limit=20
for i in $i
do
var=${i#processor/}
flag=`awk -v lim=$limit -v current=$var '{if (var>=limit) print GO}'`
if [ -n $flag ]
then
for j in $listP
do
echo "Removing: " $j/$var
# rm -r $j/$var
done
fi
done
As you can see, I have removed the "Remove" command. You can include it, if you find the above to work satisfactory.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   July 7, 2009, 02:40
Dr. Fabian Schlegel
Allright, that is the answer I expected but I had a little hope that there is an option or a tool which I didn't found up to now to do this task. Thx Niels
kind regards,
Fabian
Old   July 8, 2009, 03:36
Prapanch Nair
prapanj is on a distinguished road
Hey,
If you just want to reconstruct only certain time directories from the processor folders you can simple do this:
reconstructPar -latestTime (which will reconstruct the latest time step)
reconstructPar -time 100 ( which will reconstruct the time step 100, or any number for that case).
The same flags can be applied in many places. Like for example, you can do
foamToVTK -latestTime
You may write a short script that reconstruct a bunch of time steps.
Hope this helps,
Cheers,
Prapanj.
prapanj is offline   Reply With Quote
Old   July 8, 2009, 03:46
Dr. Fabian Schlegel
Thx I allready know the options of reconstructPar. But I need to reconstruct a period of time. Due to Niels suggestion I worte a little bash script to remove the unnecessary time directories in every processor* folder and afterwards I use reconstructPar without any option :-D I do not use the script provided by niels above, because I am not familiar with awk and do not like it very much. But there are many ways to achieve the same without using awk. So everything works fine :-D
thk
Fabian
Old   July 8, 2009, 06:16
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Actually many of the utilities now use the timeSelector::select0() method (which uses Foam::scalarRange - http://foam.sourceforge.net/doc/Doxygen/html/classFoam_1_1scalarRange.html), so you often specify time ranges directly.
Eg,
reconstructPar -time 10:100,1000:2000,5000:
The order of the time ranges should be irrelevant. Even overlapping time-ranges should work fine.
olesen is offline   Reply With Quote
Old   July 8, 2009, 06:43
Dr. Fabian Schlegel
great, thats the information I was looking for. Thx a lot :-D
kind regards,
Fabian
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Help with parallel working instalation. Jonathan FLUENT 9 November 7, 2011 23:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
