July 13, 2009, 05:18 |
question about gravity
vivien
Hi, everybody,
I would like to simulate the contrast agent transport in blood flow in human vessel. Currently contrast agent is assumed to be a passive scalar transported by blood. So I use icoFoam coupled with caFoam in this way: #include "fvCFD.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createMesh.H" # include "createFields.H" # include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; for (runTime++; !runTime.end(); runTime++) { Info<< "Time = " << runTime.timeName() << nl << endl; # include "readPISOControls.H" # include "CourantNo.H" fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); solve(UEqn == -fvc::grad(p)); // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rUA = 1.0/UEqn.A(); U = rUA*UEqn.H(); phi = (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rUA, U, phi); adjustPhi(phi, U, p); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rUA, p) == fvc::div(phi) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); if (nonOrth == nNonOrthCorr) { phi -= pEqn.flux(); } } # include "continuityErrs.H" U -= rUA*fvc::grad(p); U.correctBoundaryConditions(); } // part added : copied from scalarTransportFoam.C // beginning of the added part ##################################### for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { solve ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) ); } // end of the added part ########################################### runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return(0); } However, we had observed some settings of CA at the bottom of vessel wall due to gravity. Does anybody have ideas how can I include gravity term into the solver for such case? should I solve for 2-phase flow(as I think it may due to the slightly different density of blood and CA which reult in the settings of CA)? Thanks!!! vivien |
July 13, 2009, 08:50 |
vivien
Can anybody give me suggestions?
Thanks in advance! Vivien |
July 13, 2009, 09:14 |
Henrik Rusche
Rep Power: 18 |
Dear Vivien,
settlingFoam might be a good starting point for you since the separation occurs due to a difference in density between the CA and the background fluid. Henrik Last edited by henrik; July 13, 2009 at 09:30. |
July 13, 2009, 10:00 |
vivien
Hi, Henrik,
Thanks for your reply. Maybe I can start to solve my problem step by step...because CA is always injected through a catheter into the vessel and then mixed with blood, do you think if I can still use icoFoam+passivescalartransport (as I posted at first)to solve the problem if CA here is assumed again to have the same density as blood(the geometry will be similar as a Y, 2 inlet2, 1 outlet, the CA and the blood will be mixed at bifurcation). My aim is to first simulate uniform mixing of 2 flow (same property, but different inlets, one inlet with CA). My idea is to give time varing velocity (because blood flow is pulsatile )for vessel inlet, and give fixed velocity to the catheter+ passivescalar transport. Do you think it is the correct way to implement? Thanks!! Vivien |
how to consider gravity in CFX | shrimp | CFX | 4 | September 8, 2008 20:41 |
help!! Question about activating gravity | mahe | Phoenics | 0 | June 7, 2008 05:03 |
Gravity question | zhou | FLUENT | 0 | February 25, 2004 13:31 |
Help: gravity in CFX | Dejun Jing | CFX | 2 | July 22, 2002 08:58 |
On gravity modelling... | Drona | CFX | 7 | November 22, 2001 10:28 |
