interFoam 1.6: Initial Co-Number too large
Old   January 10, 2011, 05:07
Default interFoam 1.6: Initial Co-Number too large
Lars Kiewidt
LarsPT is on a distinguished road
I do simulations of capillary flows with interFoam (OF-1.6). I observed Co-Numbers of 700 in the first time steps. So I decreased the maximum time step. Now the Co-Numbers are fine, way below 0.2, but the simulation takes a lot of time because of the small maximum time step limit. Is there a way to specify more advanced options for the automatic time step control or a different solutions to prevent such high Co-Numbers at the initial steps?
Thanks in advance!
Lars
LarsPT is offline   Reply With Quote
Old   January 10, 2011, 05:14
Nakul
nakul is on a distinguished road
I hope this might help: Specify the keyword maxCo in your controlDict with its value being as per your choice but less than 1. Also with put this in controlDict
adjustableTimeStep yes;
This will automatically modify your time step to maintain the "maxCo" limit.
nakul is offline   Reply With Quote
Old   January 10, 2011, 11:54
Lars Kiewidt
Thanks for your answer! I already know and use the automatic time step control.
My problem is that Co is too large only for the first three or four time steps. So I reduced maximum time step to avoid these high Co-Numbers. But now this small time step limits the time step before the Co limit is guilty. So the computation is too slow.
A workaround is that I stop the computation manually after some time and restart it with a higher time step limit. But this is not practical when you want to start a lot of cases.
So is there a more convenient solution to that problem?
Thanks,
Lars
Old   January 11, 2011, 03:58
akidess's Avatar
Anton Kidess
You could try using a very small initial deltaT, and setting your maximum deltaT to a reasonable time step. OpenFOAM will gradually increase your time step, so if you are just worried about the first few iterations this should work.
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 10:47
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
