an error message I can't resolve
Old   June 1, 2011, 15:24
Default an error message I can't resolve
Walter Schostak
wschosta is on a distinguished road
I keep on getting this error message and I'll change something (never the same thing twice) and then it will go away and pop up again a few minutes later.
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam ::Vector<double>, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam171/applications/bin/linuxGccDPOpt/VofmhdFoam"
#5 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Any thoughts would be much appreciated.
Walter Schostak
wschosta is offline   Reply With Quote
Old   June 2, 2011, 13:07
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Line 1 in your stack trace says there is a floating point exception, so somewhere you are having a problem with the math trying to do something impossible (square root of a negative, divide by zero or infinity)
Line 3 in your stack trace says there is something wrong with a division operator somewhere in your solver. Change your timestep write to every iteration and see if there is a field that goes to zero when it shouldn't. I'm not familiar with that solver, so you'll need to check the code yourself and see where division of one field by another occurs.
mturcios777 is offline   Reply With Quote
Old   June 2, 2011, 15:12
Walter Schostak
I think it ended up being a purely dimensional issue. It seems like there was something about where the dimensional error was occurring (I was dividing) that caused the error. Regardless, all is resolved.
Thank you for your help.
how to resolve the a vector normal to a cell surfa ztdep Main CFD Forum 1 August 6, 2008 14:42
???how to resolve 'FLEXlm' error. plz help!??? rok FLUENT 1 September 28, 2007 13:29
how many points needed to resolve a vortex? Jiaying Xu Main CFD Forum 2 February 25, 2003 14:28
how many points to resolve a boundary layer? Jiaying Xu Main CFD Forum 6 January 30, 2003 11:04
Fluent 5/ASM : how to resolve the abnormality? zhou_eric FLUENT 4 June 22, 2001 00:09
