September 21, 2009, 09:42 |
OpenFOAM paraView problem
A
Rep Power: 16 |
HI,
I have a problems with running paraView in openFoam, I am running Ubuntu 9. I try to recompile but without success as described in Readme. Anyone with the same problem? Thanks |
September 22, 2009, 01:49 |
Check the Installation Forum
Alan Russell
Rep Power: 16 |
Getting ParaView to work is a frequent problem with O.F. installations. I recently got everything running on an old laptop with a clean installation of Ubuntu 9.04 and using Synaptic to install libqt4-dev and build-essential packages. After that, ParaView ran without re-compiling.
If this doesn't work for you, search the Installation forums. There are some helpful install scripts and successful methods posted by other users. Good luck, Alan |
September 22, 2009, 05:32 |
Paraview problem
A
Rep Power: 16 |
Hi Alan,
Thank you for your help! I will redo my installation of openfoam to see that I have done nothing wrong. I have now installed the libqt4-dev (I hade libqt3-dev before on my Ubuntu 9.04.). Thanks once again! |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 7 | July 30, 2009 03:14 |
Urgently need to install OpenFOAM: paraview problems. | rieuk | OpenFOAM Installation | 15 | July 4, 2009 12:40 |
OpenFOAM 1.4.1 with ParaView 3 | marico | OpenFOAM Installation | 0 | June 25, 2009 03:33 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 11:32 |
[OpenFOAM] Some problem with paraview | thermo | ParaView | 10 | December 25, 2005 13:20 |
