patching the inlet field from a file
Old   September 25, 2009, 15:49
Default patching the inlet field from a file
vishwanath somashekar
vishwa is on a distinguished road
I had posted a thread this morning regarding the same..but I am not sure if I explained myself clearly..
I ran a simpleFoam simulation on a rectangular channel. the flow is laminar.. I was able to include a file sampleDict in the system folder, which basically saved the velocity fields at the outlet of the channel. I am including that for the reference..
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      sampleDict;
interpolationScheme cellPoint;
setFormat raw;
surfaceFormat     foamFile;
sets ();
surfaces
    _left
    type patch;
    patchName outlet_left;
        /*name      plate;
        basePoint (0 0 0.25);
        normalVector (0 0 1);*/
fields
    U
Now I have to start another simulation in a reactor..I need to using the velocity field that i save using the above procedure as the inlet bc..Could anybody please explain how that is done in openfoam..
Regards,
vishwa
vishwa is offline   Reply With Quote
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
