Thin liquid FILM breaks with InterFOAM
Old   June 24, 2010, 18:22
Default Thin liquid FILM breaks with InterFOAM
Ovie Doro
ovie is on a distinguished road
Hi
I am simulating thin film flows driven by gravity on a vertical flat plate. I am using InterFoam with water-air mixture. The domain is initialized to a uniform film thickness over the length of the plate and uniform velocity. The pressure is initialized to zero everywhere.
The simulation runs for a verry short while and just when waves start forming on the surface, the liquid film breaks.
This is not consistent with results in the literature.
Does anyone have experience with this? Does this have to do with my initalization?
Thanks.
ovie is offline   Reply With Quote
Old   June 25, 2010, 07:09
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Why did you initialize with uniform velocity?
Maybe a zero velocity suits better?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   June 25, 2010, 12:32
Ovie Doro
The velocity is initialized to non zero values using Nusselt's theory but pressure is initialized to zero everywhere.
Have you been able to benchmark any thin falling film results? I would like to know more about the problem set up. Maybe I am not setting up the problem well.
Thanks
Old   June 25, 2010, 13:07
sega's Avatar
Sebastian Gatzka
No. I was just brainstorming in this case.
Old   June 25, 2010, 13:10
Ovie Doro
OK. Thanks all the same. But have you successfully run thin film flows using InterFoam? do you experience any film breaks?
Old   June 25, 2010, 13:18
sega's Avatar
Sebastian Gatzka
No, sorry. I was using interFoam for bubble growth simulations.
VOF problem, liquid film thickness Pedro24 FLUENT 0 May 13, 2009 05:57
Reversed flow error with thin film heater MK FLUENT 1 February 12, 2009 10:26
Thin film flow in triangular duct Swapnil CFX 4 December 4, 2002 16:08
liquid film modeling David Carnaga Main CFD Forum 2 July 18, 2002 21:07
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
