Residuals in the log file
Old   October 29, 2009, 06:05
Default Residuals in the log file
jml
Jml
jml is on a distinguished road
Hi everyone,
I use cavitatingFoam, and I usually redirect the terminal output to a log file
that can be viewed later (cavitatingFoam > log).
Each time step, the code shows the following data:
Time = 6.89243e-10
DILUPBiCG: Solving for rho, Initial residual = 0.0446275, Final residual
= 3.04602e-11, No Iterations 1
max-min rho: 869.997 865.673
max-min gamma: 0 0
DILUPBiCG: Solving for Ux, Initial residual = 0.0297357, Final residual =
4.13384e-10, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.029718, Final residual =
4.13323e-10, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.0690214, Final residual =
9.63771e-10, No Iterations 1
GAMG: Solving for p, Initial residual = 0.011162, Final residual =
3.51462e-09, No Iterations 3
max-min p: 8e+07 5.04471e+07
max(U) 20.6549
max-min rho: 869.997 855.221
max-min gamma: 0 0
GAMG: Solving for p, Initial residual = 0.00340274, Final residual =
2.19309e-09, No Iterations 3
max-min p: 8e+07 5.06173e+07
max(U) 20.6766
max-min rho: 869.997 855.306
max-min gamma: 0 0
GAMG: Solving for p, Initial residual = 0.00019062, Final residual =
2.68717e-09, No Iterations 2
max-min p: 8e+07 5.06262e+07
max(U) 20.6778
max-min rho: 869.997 855.31
max-min gamma: 0 0
ExecutionTime = 147.81 s ClockTime = 148 s
What can I do to avoid the lines referred to the residuals? What files do I must modify?
Thanks
jml is offline   Reply With Quote
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 14:30
Residuals in the log file jml OpenFOAM Programming & Development 1 July 20, 2012 08:13
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
recording residuals in a seperate file khairy FLUENT 0 June 30, 2006 22:35
