Mapfields with two different turbulence models
Old   November 4, 2009, 10:23
Smile Mapfields with two different turbulence models
AirS is on a distinguished road
Dear Foamers,
I've got two meshes (coarse/fine) and I use a different turbulence model for both of them. Basically, I was wondering if it was possible to use Mapfields in order to import results from coarse mesh as an initial condition for the fine mesh which uses another turbulence model.
Thanks!
AirS is offline   Reply With Quote
Old   November 16, 2009, 01:35
N/A
harishg is on a distinguished road
The initial conditions on the turbulent variables do not matter a lot. As long the the velocity field is perturbed, turbulence will develop and you should be able to obtain statistics.
harishg is offline   Reply With Quote
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Turbulence Models and external flow. Alan FLUENT 3 November 22, 2005 04:46
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
