August 19, 2009, 15:51 |
openfoam 1.5-dev on opensuse10.3-64bit
Disabled
Rep Power: 16 |
this is the foamInstallTest what it gives out
(after tar -xfz Openfoam-1.5_dev thirdparty _ general and gcc64 ) and then .bashrc editing and resource and that is the flouing error i get?? could any one help Executing /home/ammar/OpenFOAM/OpenFOAM-1.5-dev/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: ifm-pc87 OS: Linux version 2.6.22.19-0.3-default ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/ammar/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/ammar/OpenFOAM/ammar-1.5-dev yes no $WM_THIRD_PARTY_DIR /home/ammar/OpenFOAM/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/ammar/OpenFOAM/OpenFOAM-1.5-dev yes yes yes $FOAM_APPBIN ...dev/applications/bin/linux64GccDPOpt yes yes yes $FOAM_USER_APPBIN ...dev/applications/bin/linux64GccDPOpt yes yes no $WM_DIR ...mmar/OpenFOAM/OpenFOAM-1.5-dev/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OpenFOAM-1.5-dev/lib/linux64GccDPOpt yes yes yes $FOAM_USER_LIBBIN ...AM/ammar-1.5-dev/lib/linux64GccDPOpt yes yes no $MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version : ../configure 4.2.1 Minimum required: 4.2.0 gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /usr/bin/gzip tar 1.17 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/ammar/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_ifm-pc87 Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
August 20, 2009, 14:41 |
Disabled
Rep Power: 16 |
hi the problem is solved it was my mstak thank you alot
December 4, 2009, 00:33 |
Srikara Mahishi
Rep Power: 17 |
Hello Tajoooko,
I have the same problem while installing OF-1.5-dev on my suse-10.3 64bit. Could you please tell me how you solved the problem?? Thank you in advance, Srikara |
k Omega SST SAS for OpenFOAM 1.5??? | barath.ezhilan | OpenFOAM Running, Solving & CFD | 3 | June 2, 2010 07:41 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
OpenFOAM 1.5 installation on OpenSUSE 11.0 | bigphil | OpenFOAM Installation | 16 | April 29, 2009 06:28 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
OpenFOAM Version 1.5 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 14, 2008 18:22 |
