Runnin GGI interface
Old   September 22, 2009, 06:41
Default Runnin GGI interface
Pramod
pramodopen4foam is on a distinguished road
Hi friends,
I am trying with a tank model with rotating propeller in it, I have got meshes from fluent and successfully converted that to foam Mesh, now my question is,
1) How to merge this 2 different meshes so that after merging I have to give rotation to propeller as explained in GGI tutorial,
2) Is stitch mesh command required after merging , since I have to rotate my propeller mesh,
can anyone help me with this,
I am very new to OpenFoam,
Thanks in advance
pramodopen4foam is offline   Reply With Quote
Old   September 22, 2009, 07:53
Simon Lapointe
Simon Lapointe is on a distinguished road
1) Once you have your two meshes in foam format, you need to place them in two different case folders like "master" and "propeller". Then you use the command "mergeMeshes . master . propeller". This will a create a new timestep in the master folder with the complete mesh.
2) You don't need to use stitchMesh. Once you set up the boundary conditions properly, you can give motion to your mesh using the dynamicFvMesh "mixerGgiFvMesh" (if you want to give a constant angular velocity). You'll need to specifiy the moving and static boundaries you defined earlier.
Hope that helps
Simon Lapointe is offline   Reply With Quote
Old   September 22, 2009, 08:06
Pramod
Originally Posted by Simon Lapointe View Post
Hope that helps
Thanks for your kind response Simon, will try that now ,
Old   September 22, 2009, 08:20
Unhappy Got an error
Pramod
tried with the commands MergeMeshes .body .attachment ,
I landed in error like "Wrong number of arguments, expected 4 found 2" ,
I know its because of Path error but mine is very simple both(body n attachment mesh casses) are in a folder in Desktop.
Thanks in advance,
Pramod
Old   September 22, 2009, 08:27
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi
i want to know if the GGI can run in parallel in OpenFOAM 1.6 (not 1.6.x)
3ks
wayne
waynezw0618 is offline   Reply With Quote
Old   September 22, 2009, 08:46
Simon Lapointe
Thanks in advance,
Pramod
Try with a space between "." and "body" like ". body"
Old   September 22, 2009, 08:48
Simon Lapointe
Originally Posted by waynezw0618 View Post
Hi
3ks
wayne
I don't think GGI is available in OpenFOAM 1.6. It is available in 1.5-dev and it can run in parallel.
Old   September 22, 2009, 09:05
Pramod
Thanks Simon again,
this time providing space worked, but ended in error ,
"Writing combined mesh to 0.1
Patch face has got a neighbour. Patch ID: 6. This is not allowed.
Face: 3(50622 26674 27282) masterPointID:-1 masterEdgeID:-1 masterFaceID:-1 patchID:6 owner:109183 neighbour:109178#0 Foam::error:rintStack(Foam::Ostream&) in "/home/baburao/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/baburao/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam:olyAddFace:olyAddFace(Foam::face const&, int, int, int, int, int, bool, int, int, bool) in "/home/baburao/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/mergeMeshes"
#3 Foam::mergePolyMesh::addMesh(Foam:olyMesh const&) in "/home/baburao/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/mergeMeshes"
#4 main in "/home/baburao/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/mergeMeshes"
#5 __libc_start_main in "/lib/libc.so.6"
#6 Foam::regIOobject::write() const in "/home/baburao/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/mergeMeshes"
From function polyAddFace
const face& f,
const label owner, const label neighbour,
const label masterPointID,
const label masterEdgeID,
const label masterFaceID,
const bool flipFaceFlux,
const label patchID,
const label zoneID,
const bool zoneFlip
in file /home/dm2/henry/OpenFOAM/OpenFOAM-dev/src/dynamicMesh/lnInclude/polyAddFace.H at line 246.
FOAM aborting"
My question was can we successfully merge meshes in OpenFoam-1.5?
I have attached my 2 master n slave boundary files below, If possible please see this,
again thanks you very much,
Pramod
File Type: gz Tankwithrotor.tar.gz (712 Bytes, 23 views)
Old   September 22, 2009, 10:53
Simon Lapointe
Thanks Simon again,
const face& f,
const label zoneID,
const bool zoneFlip
FOAM aborting"
Pramod
Yes, it is possible to merge meshes in OpenFOAM 1.5. However, I see from your error messages that you seem to be using OpenFOAM 1.5 and not 1.5-dev. If that's the case you won't be able to use GGI since it is not available in 1.5.
Concerning the mergeMeshes problems, I can't tell the problem from your boundary files.
Old   September 22, 2009, 10:59
Default GGI interface not working
Pramod
Hi friends as I suggested mergeMeshes works in OF-1.6, but once simulation is complete we cannot see fluid passing through second domain or propeller mesh,
its clearly indicated, is GGI interface working, does propeller rotote can anyone help me in implementing GGI mesh, I ll attach my merged mesh as well as jpg of result file and DymMeshDict,
Thanks in advance,
Pramod
Old   September 22, 2009, 11:03
Pramod
Thanks for your reponse again Simon,
Is GGI available in OpenFoam.1-6 ???
Thanks,
Pramod.
Old   September 22, 2009, 11:11
Simon Lapointe
Thanks,
Pramod.
As I mentionned in a previous post, GGI is not available in OpenFOAM 1.6. At the moment, it is only available in 1.5-dev.
Old   September 22, 2009, 11:17
Pramod
Thank you very Much Simon,
Can we be in contact so that you can help to know this software well ,
Anticipating for your kind reply,
Old   March 12, 2010, 11:56
Nick Gardiner
NickG is on a distinguished road
Thanks in advance,
Pramod
Hi Pramod
Did you find the answer to this problem. I have the same problem when I try to run in parallel but not on one cpu.
Cheers
Nick
NickG is offline   Reply With Quote
ggi, mergemeshes
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
CFX GGI Interface Error (non-overlapping) surge519 CFX 1 August 3, 2009 18:54
GGI Interface Frozen Rotor Kramer CFX 1 July 13, 2005 13:03
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
