Schemes to improve pressure drag?
Old   December 2, 2009, 03:55
Default Schemes to improve pressure drag?
Charles
CapSizer is on a distinguished road
I'm analysing a series of 3D streamlined shapes with simpleFoam, using meshes created with snappyHexmesh. As far as I can make out, the meshes are OK, as they produce drag figures in Fluent that quite closely match what I was able to achieve with a very high quality block-structured hexahedral mesh. The Fluent results make sense, with pressure drag making up about 10% of the total drag. Re-number based on length is about 10 million, and the finess ratio is around 7. In Fluent I know that least squares interpolation combined with second order momentum differencing is required to get the accuracy. However, in simpleFoam I'm getting pressure drag that is about 4 times too high. FWIW, I'm using the SST turbulence model with wall functions, but changing the turbulence model does not make much difference here. I suspect that although I'm using higher order schemes, there is something important that I am missing. Any suggestions, please?
CapSizer is offline   Reply With Quote
Old   December 10, 2009, 04:39
Robert Castilla
rcastilla is on a distinguished road
Maybe it is a problem with wall function. Have you checked the value of yPlus?
rcastilla is offline   Reply With Quote
pressure drag, schems, simplefoam
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 07:26
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Pressure Condition sidd Siemens 0 April 2, 2007 09:31
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
