January 14, 2010, 15:17 |
OpenFOAM 1.6 on CentOS 4.x
Joaquín J. Correa
Rep Power: 16 |
Has anyone successfully install the latest OF version on CentOS 4.x?, Can anyone provide me a link for OF 1.3 download?
Regards. |
January 15, 2010, 01:52 |
Niels Nielsen
Rep Power: 27 |
I installed it on a cluster running RHEL 4.x and it works fine. We have although upgraded to Rocks 5.x which as you might have guessed is based on CentOS 5.x.
It is doable but you need to compile a lot of stuff from source to get the right dependencies. It's much easier with 5.x. 1.3 download http://sourceforge.net/projects/foam/files/
Linnemann PS. I do not do personal support, so please post in the forums. |
January 15, 2010, 05:30 |
Cedric Van Holsbeke
Rep Power: 16 |
Try this: http://centfoam.sourceforge.net/
January 15, 2010, 11:05 |
#4 | |
Joaquín J. Correa
Rep Power: 16 |
January 15, 2010, 11:09 |
Niels Nielsen
Rep Power: 27 |
Hi
As I am the maintainer of CentFOAM I will answer the question There is no differences from the official version. The difference is it is built against CentOS libraries and those not directly available via yum, are added to the Thirdparty package. So basically its easier to install this on CentOS than the official release. Also there are some mesh related packages on the project page which works natively on CentOS.
January 15, 2010, 11:20 |
#6 | |
Joaquín J. Correa
Rep Power: 16 |
January 15, 2010, 11:21 |
Niels Nielsen
Rep Power: 27 |
Hi
I haven't tried it on 4.x but I doubt it will work. It is built against the 5.x release.
January 15, 2010, 11:22 |
Joaquín J. Correa
Rep Power: 16 |
Thanks; Regards.
centos, of 1.3, openfoam 1.3 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 12:46 |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 7 | July 30, 2009 03:14 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
