January 18, 2010, 01:56 |
Can't run channelFoam!!
New guy
Rep Power: 16 |
when i run a channelFoam ,there was a error
--> FOAM FATAL IO ERROR: Illegal master cellID 1001. Should be 0..24 file: /home/lequilam/Desktop/testpaallel/GEOM_2954_TestParal/system/fvSolution::PISO from line 71 to line 74. From function void Foam::setRefCell ( const volScalarField&, const dictionary&, label& scalar&, bool ) in file cfdTools/general/findRefCell/findRefCell.C at line 65. can anybody help me to answer that problem? thank in advance. |
January 18, 2010, 04:04 |
Dr. Fabian Schlegel
Rep Power: 18 |
Look into the system directory of your case. There should be a dictionary file named fvSolution. Change the pRefCell to a valid value.
PISO { nCorrectors 3; nNonOrthogonalCorrectors 5; pRefCell 0; pRefValue 0; } All information you need to avoid or to find this error was written by OpenFoam to your terminal. Please read the output carefully before asking :-D Fabian |
January 18, 2010, 04:51 |
New guy
Rep Power: 16 |
Thanks. That's a big mistake...I will take care next time.Thanks again !!
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 14:43 |
What's the best order to run this simulation in? | siw | CFX | 1 | November 4, 2009 19:42 |
serial run fine, but parallel run diverged | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | October 6, 2009 08:33 |
Cycling a transient run | Chetan Mistry | Phoenics | 0 | March 3, 2004 09:50 |
