Face merging, patch definition, wall function
Old   March 24, 2010, 06:07
Default Face merging, patch definition, wall function
Sandu69 is on a distinguished road
Hello foamers,
I have a problem using blockMesh:
I want to attach a cylinder face to a bigger rectangular block face using the command "mergePatchPairs".
The goal is, that the cylinder face is completely merged to the block face, whereas the remaining block face should become a wall with wall functions applied.
That's my question:
How should I define the patches and boundary conditions?
I already tried it, but it did not work. That's how I defined everything:
File "blockMeshDict":
patches
patch cylinderface
(1 2 3 4)
wall blockface
(5 6 7 8)
mergePatchPairs
(cylinderface bottomface)
Boundary file 0/epsilon (i.e.):
boundaryField
bottomface
type epsilonWallFunction;
value uniform 0.000765;
I got the following error:
"Invalid wall function specification
Patch type for patch bottomface must be wall
Current patch type is patch"
What does it mean? I defined the block face as a wall!
Can anybody help me with this?
Thanks,
Stephan
Sandu69 is offline   Reply With Quote
Old   March 24, 2010, 11:17
Piotr Prusinski
piprus is on a distinguished road
patches
patch cylinderface
(1 2 3 4)
wall blockface
(5 6 7 8)
mergePatchPairs
The only one thing I can't understand here is how could you merge the bottomface to anything, without specifing it in a patch list?
piprus is offline   Reply With Quote
Old   March 24, 2010, 11:48
The patches are defined in the blockMeshDict file.
I solved the problem by deleting and recreating the boundary file.
No everything works well :-)
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
