Run laminar in buoyantBoussinesqPisoFoam
Old   April 9, 2010, 03:25
Default Run laminar in buoyantBoussinesqPisoFoam
Wang Jingxuan
fatcat is on a distinguished road
Send a message via MSN to fatcat
Hi,foamers,
I'm trying to change RANS models into laminar in buoyantBoussinesqPisoFoam. the way I used is from "http://openfoamwiki.net/index.php/BuoyantBoussinesqPisoFoam". But, when I try to run wmake. It have a mistake, make: ***[/home/wang/OpenFOAM/OpenFOAM1.6.x/applications/bin/linux64GccDPOpt/buoyantBoussinesqPisoFoam] errorー 1. However, In file "linux64GccDPOpt", I can't find the document named buoyantBoussinesqPisoFoam. After that, I also do the same thing in buoyantBoussinesqSimpleFoam, and it works.
So, Is it the cause of the mistake is the losing of buoyantBoussinesqPisoFoam. If it is, Shall anyone send me the document.
Thanks
Wang
fatcat is offline   Reply With Quote
buoyantboussinesqpisofoam
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 13:37
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 08:33
Laminar field as initial state for turbulent two phase pipe flow kjetil OpenFOAM Running, Solving & CFD 3 July 21, 2009 09:15
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
Restatring run Tim CFX 2 March 3, 2006 11:54
