March 8, 2010, 05:28 |
The correct BCs for defining an "open room".
Rep Power: 16 |
Hello dear Foamer,
I am struggeling for some time with the problem defining the boundary conditions correctly. What is my aim? The domain should be an "open room", that means there is a free air exchange, so that air can flow into the domain and as a result the domain's temperature is always constant. As an example 293 kelvin. I don't find the correct BC-parameter for my domain, so the simulation always aborts and/or there is no really air exchange. If I define all boundaries as walls, the simulation is working stable, but then there won't be any fresh air exchange and the air heats up. So maybe some of you have experience with this issue and can help me a bit Best regards. Last edited by suitup; March 8, 2010 at 06:36. Reason: spelling |
March 8, 2010, 06:18 |
Cean
Rep Power: 16 |
which slover are you using?
I am also interted in room ventilation. |
March 8, 2010, 06:35 |
Rep Power: 16 |
I am using the chtmultiregion-solver, but actually there shouldn't be so much difference between the solvers I guess (or hope ) |
March 8, 2010, 14:32 |
Gregor Olenik
Rep Power: 16 |
hi
you should have a look at the interFoam tutorial for the use of atmospheric boundary conditions |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 11:58 |
