ZeroGradient pressure Outlet BC prob (adjustPhi.C)
Old   March 23, 2010, 05:52
Default ZeroGradient pressure Outlet BC prob (adjustPhi.C)
Stylianos Kyriacou
Stylianos is on a distinguished road
Hello Everyone
I've been trying to set-up a Rotor-Stator case for MRFSimpleFoam (my goal is to obtain an initial solution to then use with turbDyMFoam for an unsteady calculation).
I've succeeded on getting a converged solution via MRFSimpleFoam but i observed that i had a strange pressure distribution near the outlet (a pressure step exactly at the last nodes before the outlet). After some search in previous threads i found out that a good idea is to use zeroGradient (with pRefCell and pRefValue) as outlet BC.
My initial BCs were:
U:
INLET
type flowRateInletVelocity;
flowRate 0.750;
value uniform (0 0 0);
OUTLET
type inletOutlet;
inletValue uniform (0 0 0);
P:
INLET
type zeroGradient;
OUTLET
type fixedMeanValue;
meanValue 0;
My modified BCs are:
U
INLET
flowRate 0.750;
OUTLET
type zeroGradient;
P:
INLET
type zeroGradient;
OUTLET
type zeroGradient;
but with the new BC set up (and although i initialized my U field with a sensible value) i get this error:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Specified mass inflow : 0.75
Specified mass outflow : 0
Difference : 0.75
Adjustable mass outflow : 0
I've then went to adjustPhi.C to check out (maybe i was missing something) and i've seen that the part that calculates Specified mass outflow, Specified mass inflow and Adjustable mass outflow has undergone a recent bug fix (// HJ, 12/Feb/2010) and i was wondering if someone had successfully used it since then ?
Thanks for your help
Stylianos
Stylianos is offline   Reply With Quote
Old   March 23, 2010, 08:44
Default Pressure step exactly at the last nodes before the outlet
Stylianos Kyriacou
Old   March 23, 2010, 09:38
Kevin Smith
kev4573 is on a distinguished road
Your BCs on pressure are not well defined; try using total pressure on the outlet.
kev4573 is offline   Reply With Quote
Old   March 23, 2010, 12:28
Stylianos Kyriacou
If the outlet is part of the rotating portion of the mesh dose that create a problem for MRFSimpleFoam?
Outlet pressure for compressible flow Michelle CFX 12 September 1, 2015 18:38
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Pressure Drop in outlet Vent Abdul FLUENT 2 October 28, 2008 12:13
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 10:44
