How to choose end time for a steady state problem
Old   March 5, 2010, 02:46
Question How to choose end time for a steady state problem
KGN
mecbe2002 is on a distinguished road
I am using "rhopSonicFoam" solver for solving 3d steady inviscid flow around ONERA M6 wing. How to decide the end time?
Ma=0.84, alpha=3.04
Properties of air R-287.05 J/kgK, gamma-1.4, T-255.6K
Computational domain size is 11m x 5m x 10m (Hexahedral).
No.of cells = 341797
time step = 5e-07
mecbe2002 is offline   Reply With Quote
Old   March 5, 2010, 05:54
djbungee's Avatar
Ulf Bunge
djbungee is on a distinguished road
that is an interesting question. My suggestion is that you observe the development of the initial residuals for every equation for the cycles ('time' steps).
If you have sufficient (computation) time and perform this (kind of) simulation or case setup for the first time, I would suggest you do the simulation as long as possible to get an idea of how the residuals develop over computation time (and how low they can go) and try to find a suitable optimum for quality of results (i.e. reduction of change in residual for every cycle - which is not always the same ) and computational effort (time).
So, unfortunately, no general guideline available ...
Best regards, Ulf.
djbungee is offline   Reply With Quote
Old   March 25, 2010, 21:49
Alberto Passalacqua
You can additionally track the evolution of which you know the behaviour, and check when it stops evolving.
It is always a good idea to add a "physical" convergence criterion to the one based on residuals.
Best,
Alberto Passalacqua
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Single Bubble Gerrit Senger CFX 4 March 12, 2007 16:29
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Has anyone successfully used transition modell..p2 PetrK CFX 12 May 26, 2006 16:27
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
