can you share cylinder forces results ?
Old   March 29, 2010, 08:41
Default can you share cylinder forces results ?
Marine
marine is on a distinguished road
hello!
I'm trying to learn how calculate forces with OpenFOAM 1.6 and I'm doing simulation for a 2D cylinder of 1m diameter in an incompressible viscous flow with a velocity inlet of 1m/s (Re=1.10^6). I'm using simpleFoam and k-epsilon turbulence model. I'd like to know if someone already runned this simulation with thoses values (or even other) and would like to share the results for the forces on the cylinder.
Thanks a lot in advance.
Marine
marine is offline   Reply With Quote
Old   March 29, 2010, 15:20
Default Kind of
bjr
Ben Racine
bjr is on a distinguished road
Send a message via AIM to bjr Send a message via Skype™ to bjr
I've done similar, but with k-omega SST and on a geometry I can't provide you, but I did match drag results within 15%. I'd be happy to discuss, provide setup, discuss getting forces, etc.
i3enhamin@gmail.com
bjr is offline   Reply With Quote
Old   March 29, 2010, 22:42
lin
Hua Zen
lin is on a distinguished road
I remember that k-epsilon is not good for such simulation.
lin is offline   Reply With Quote
Old   March 30, 2010, 04:20
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
The results are based on Std-Wallfunctions with High-Re Models for smooth cylinder. I havent tested nutSpallartAllamarsWall function.
The experimental values are also varying very much. I recommend you to have a look at this paper for more Refernece about the experimental data.
http://ctr.stanford.edu/ResBriefs01/wang.pdf
Have a look at the Plots and Tables as attached.
Good luck !
maruthamuthu_venkatraman is offline   Reply With Quote
Old   March 30, 2010, 10:40
Marine
Thanks for your answers and for the paper !
Lin which model do you think is better for such simulation?
Old   March 30, 2010, 22:27
lin
Hua Zen
Just try some other two-equation turbulence closure other than standard k-epsilon. I think those would be better.
Old   March 31, 2010, 12:03
Marine
Hi!
I tried differents simulations and I have very stranges results, they are so differents and the convergence of the calcul vary a lot between the simulations.
My BCs and results are in cylinder2d.zip, if you are interested in it and can't open the file I can send you by mail.
so I'd like to know if anyone knows why the results are so differents, and if I can improve my boundary conditions or my turbulent model?
thanks a lot !
Marine
[IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG][IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
Old   April 16, 2010, 04:45
I hope you fixed the errors. If not just check these variables.
1. Type yPlusRAS and see the values and plot them in paraView. May be you are using wall function with inappropiate near wall spacing. Check it out.
2.check the discretization schemes as well. I guess you are use 1 st orders scheme for U.
3 Regarding BC's just review turbulence modelling for wilcox. Hope its clarifying you..
Good luck
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 10:54
[ICEM] Problem with boundary layers for cylinder in channel nik ANSYS Meshing & Geometry 0 October 27, 2009 06:01
Flow past cylinder (Re=10^5) lbeaudet Main CFD Forum 9 June 2, 2009 03:59
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 10:50
